Need manual
Contact your original retailer or Sears Help
http://www.searspartsdirect.com/partsdirect/user-manuals/141022/38518221800-Kenmore-Parts-SEWING+MACHINE-manual?pathRender=fromManualTabPage
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning
with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test
it to make sure the tension is working correctly.
(To do this
test,adjust your tension setting to normal or medium or 5 or something
in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the
thread. It should pull noticeably harder.) If it passes this test,
continue up through the take up lever,then down through the thread
guides to the needle. Make sure your needle is fully inserted and
turned the correct way.( If you load your bobbin case from the left
side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are
some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
SOURCE: Manual for Kenmore sewing machine, model 385.12812690
So far I've only been able to find this page. It's $8.00 to download. Considerably cheaper than a new machine!
http://www.sewconsult.com/kenmore_instruction_manual_385_oce_type1.htm
Hope it helps.
