Question about Cycling
Mountain bike manual
Bought a Sabre Sportz Kinetic mountain bike and came with wrong manual. Need manual for this bike
  • Roberta Smith
    Roberta Smith May 11, 2010
    have you tried to ask them at the place you purchased the bike ?
goalie39
  • 469 Answers
SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Posted on Apr 19, 2009
  • 200 Answers
SOURCE: instruction manual to put bicycle together.
Too long and complicated to go over everything sooo....Google bicycle assembly and your answers are at your fingertips....good luck to you friend....Tim
Posted on May 12, 2009
herodog909
  • 98 Answers
SOURCE: mountain bike repair manual
http://www.utahmountainbiking.com/fix/
Please please rate.
Posted on Jun 19, 2009
billfox1966
  • 231 Answers
SOURCE: I HAVE A MGX MOUNTAIN BIKE. WERE THE PEDAL ARE
im certain that model has a 3 piece crank set up. the inner crank bearing jam nut has loosened up or the bearings themselves have gone bad.first check to see if its tight, if it is then it will require a replacement set of bearing that are a pretty standard size to all bikes and can be purchased at nearly every bike shop.
Posted on Jul 09, 2009
SOURCE: next power x mountain bike
is there a way to tighten the from shocks so i dont bottom out?
Posted on Apr 28, 2011
I would like to know the size of the frame on the Mongoose 29in Torment Men's mountain Bike
18" Frame
Bicycles in Brand:Mongoose, Gender:Men, Wheel Size:29" ' eBay
https://www.ebay.com > Sporting Goods > Cycling Equipment > BicyclesResults 1 - 48 of 80 - 29" Mongoose Status 2.6 Men's Mountain Bike, 18-Inch frame, White ... The Mongoose 29in torment mountain bike will provide for hours of ...
Mongoose 29in Torment Mountain Bike - Kmart
www.kmart.com/mongoose-29in-torment-mountain-bike/p-080W004611130001P
Rating: 5 - โ€Ž1 review
Oct 27, 2012 - Enjoy Fresh Air with this Rugged Mongoose Torment Bike 21 Speed The Mongoose 29in torment mountain bike will provide for hours of safe riding in th... ... Wheel Size: 29 in. ... Gender: Male ... It's rare to find an aluminum frame at this price point. As I wheeeled it up to the counter, many people stopped to ...
Mongoose 29" Front and Rear Disc Brake 21 Speed Mens Torment ...
https://www.amazon.com/Mongoose-Front-Brake-Torment-Mountain/.../B075CQPV5... Rating: 4.2 - โ€Ž3 reviews
... and Rear Disc Brake 21 Speed Mens Torment HD Mountain Bike : Sports & Outdoors. ... power; Alloy frame with formed tubes and internal cable routing for clean look .... Product Dimensions: 58 x 10.2 x 33.8 inches ; 52.3 pounds; Shipping ...
Mongoose 29in Torment Mountain Bike - Sears
www.sears.com/search=mongoose%2029in%20torment%20mountain%20bike Mongoose Torment 29" Mountain Bike ยท 2.0. (1)Sold by Sears. add to comparecompare now. Mongoose 29" 21Speed Mens Torment HD Mountain Bike.
Mongoose Torment 29" Mountain Bike - Sears
www.sears.com/mongoose-29in-torment-mountain-bike/p-00654966000P Rating: 2 - โ€Ž1 review
Feb 23, 2014 - Mongoose Mongoose Torment 29" Mountain Bike 1 ... A durable aluminum frame handles rugged trails and roads; Front and rear brakes with easy-to-reach handles for safe stopping ... Wheel Size: 29 in. ... Gender: Male ...
Bicycles in Brand Mongoose Gender Men Wheel Size 29 eBay
May 29, 2018 | Mongoose Cycling
Raise handlebars on mountain bicycle
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
Sep 18, 2014 | Huffy Granite 26 Women's Mountain Bike
I Have a Magna Mountain tamer 15 speed bike and i need the manual for it.
i need an owners manual for a Magna Mountain tamer bike a 15 speed womens
May 28, 2011 | Cycling
How can i fix the brakes on a diamondback octane 24?
Brakes can have a number of things wrong with them, as they are a crucial part of the bikes safety and fairly complicated, this is probably not the best first time project and I would recommend taking the bike into your local bike shop.
If you insist on working on the brakes yourself, and it is good to know how to work on your brakes, then you should get a good repair manual that clearly explains the process and what tools you will need for your specific brakes.
Books are readily available at any bookstore and many bike shops (where you will be buying the parts and most likely tools, anyway)
Here is a couple of good ones. Park tool repair manual (the big blue book) and Zinn and the art of mountain bike maintance.
Dec 09, 2010 | Diamondback Octane Jr Girls' Mountain Bike...
I would like a Specialized Mountain Bike Manual
you can download it from specialized.com they have a really good site, i ride a stumpy myself and have used the site regularly
Jan 15, 2010 | Specialized Bicycle Components Specialized...
Rear mountain bike derailluer stops working,then suddenly starts
depending on how much you use the bike. you may have to replace or re-aline the gear cable that runs through the bike.
Feb 15, 2009 | Mountain Bike Bicycle Derailleur Hanger...
Cycling Logo
126 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
