Question about Microsoft Windows XP Professional
Operating system not found
Hi there I change hd from difrent pc and now it,s saing that operating system not found someone told me that i should reinstol my xp but when i,m doing this i,m getting new error partmgr.sys Mario
  • mariuszprus May 27, 2009
    i want to reinstal xp from cd but it,s saing error partmgr.sys
    President:
  • 846 Answers
You can't insert a Hard drive from another PC because when it was installed on the old PC it was setup to work with the hardware for that particular computer.
You will need to reinstall a fresh copy of windows on it to make it work with the new PC it's in.Boot from CD run windows setup, format the drive then do a fresh install.
This should fix the problem, if you have any new info or need further help with any of that post back. Thank you for choosing Fixya!
Posted on May 27, 2009
    Scholar:
  • 89 Answers
You cannot just transfer hard drives, they will not work.
however when you install the new drive and attempt to re-install your operating system, make sure that you Delete any previous Partition within the Windows Setup.
Follow these steps:
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  4. Press F8 to accept the Windows XP Licensing Agreement.
  5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  6. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select any existing partition, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that is listed
  7. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
Step 2: Format the hard disk and install Windows XP loadTOCNode(3, 'moreinformation');
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  • Format the partition by using the NTFS file system NOT QUICK!!
After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP.
    President:
  • Microsoft Master
  • 1,996 Answers
Are you using a USB flash drive to reinstall xp?
If so, see this article for possible cause of this error. partmgr.sys is MS partition manager. Read about formatting and partitioning your hard drive.by clicking here.
In any case, since you have a new hard drive what you want to do is called a clean install of xp. This will wipe the hard drive clean and install the OS and drivers for you to start anew. See link here and here. If you can, you should attempt to create a slipstreamed sp3 cd to do the new install, so you will have an updated version of the OS on the hard drive when you boot it up...
You also need to have the hardware drivers cd so you'll be able to get online and update, etc. Otherwise your hardware won't work.
If you are not attempting to start fresh, you'll want to try to do a repair install instead, which will save your data.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
  • efs_perpends
    efs_perpends May 27, 2009
    Did you reformat the drive, or are you trying to install xp into the remaining space left over from an earlier partition?
    Genius:
  • 1,847 Answers
Hi po bkit ayaw po mg sound sa speaker
Most laptops have two different sound drivers. Check your manufacturer for correct drivers. Reboot and retest! Check that you are using HD and not the digital sound system by checking your sound properties in control panel - change it to the correct one. Check that someone did not mute the sound, click the icon and check. Try different speakers, powered versus non-powered to see if there is a difference in quality.
Aug 25, 2011 | Computers & Internet
Walang microsoft ang computer. ko, hindi ako makapgtype. nung gagawin ko?
HI there,
Ano bang meron sa desktop mo? kung may windows xp na yan (operating system), kelangan mo mag-install ng Microsoft Office. Kung malapit ka lang pwede ako mag-install. Hiram ka sa mga kakilala mo, Kelangan mo ng MS Office installer para mainstall mo sa PC mo.
Kung walang lumalabas diyan sa PC mo, or walang desktop, or baka Ubuntu ang Operating system, pa-reformat mo nalang sa Windows Xp or Vista, basta kaya ng PC mo..
Follow ka lang kung hindi pa nasasagot ang iyong problema,
levibit
Dec 12, 2010 | Microsoft Windows XP Professional
Operating system OEM software disk needed.
Go on Ebay and purchase a Windows XP OS Disk with OEM number there. Make sure its Original and not someone's copy. I use WIndows XP Professional myself.
Oct 21, 2009 | Dell Dim.9150 Pentium D 820 Dual...
How to install arabic in my pc
Hi
You can go to www.microsoft.com and find your solution otherwise follow the link this might help :
http://www.google.com.pk/url?sa=t&source=web&ct=res&cd=4&url=http%3A%2F%2Fen.kioskea.net%2Fforum%2Faffich-10659-how-can-i-change-the-opareting-system-languag&ei=9L3HSv2jOIKIkQWO0Zw8&rct=j&q=OS+language+change+&usg=AFQjCNF7gLXexMgIfV85qr2Jsx-G06E2KQ
Oct 03, 2009 | Microsoft Windows XP Professional for PC
I have a HP A6667c Desktop. Would I be able to do a complete HD format and install XP? I was told that drivers might not be available.
According to HP the Pavilion A667 desktop PC does not support the XP operating system.
You can however try to install XP to see what happens, if you do decide to try and install XP make sure you make or have at least got a recovery disk for Vista before you install XP.
Good luck.
Sep 14, 2009 | HP Computers & Internet
When installing a used hd...PC says no hard drive found
Do you have another harddisk installed already if so, you need to change the jumper settings maybe both the hardisks are having the jumper positioned as master device. which u need to set ur OS or Operating software HDD to master and the second one as a slave.
Nov 12, 2008 | Microsoft Windows XP Professional
Changing an english computer over to spanish
to change your operateing system language you need to get the windows in that language. There are many difrent versions of windows in difrent languages.
If I want my xp to be in finnish I have to get my hands on a CD which is in finnish. IF I want english I need a english version of the cd.
You will need a spanish xp setup cd.
also it may be possible to convert xp into another language. with some
Windows XP Multilingual User Interface (MUI)
I hear it costs money and I haven't used or tryed it.
Jun 27, 2008 | HP Pavilion dv6000z Notebook
Changing windows xp's language
You have to install a spanish version of xp. there are difrent versions of xp for most languages.
Apr 22, 2008 | Microsoft Windows XP Professional
Minolta Dimage Scan Dual ll
Hello ! I try to use many difrent driver in difrent mod. eks:95,98,2000,xp
The best was 98,butt it still stops when the scanning starts.
Solution for my problem.......Vuescan from Hamrick.com
Mvh
Vidar
Norway
Feb 24, 2008 | Minolta Dimage Scan Dual II Film Scanner
Microsoft Windows XP Professional Logo
297 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
