Good day! I have a A93.0500 Maxtor 6L060J3 hard drive. I no longer have the manual for setting the jumpers. What are the jumper settings for making this drive the master? Currently it is the slave dri
Good day! I have a A93.0500 Maxtor 6L060J3 hard drive. I no longer have the manual for setting the jumpers. What are the jumper settings for making this drive the master? Currently it is the slave drive.
  • 432 Answers
It should show you on the actual drive what the settings are - if not you will have to look on the maxtor website - they should have a support section where you can download the manual for that drive
Posted on May 27, 2009
Maxtor hard drive jumper settings for model 7245At maxtor hard drive jumper settings for model 52049h3
1. Jumper settings for model 7245At refer to LINK
2. jumper settings for model 52049h3 refer to LINK
Hope it helps.
Jun 22, 2011 | Maxtor Hard Drive
What is the jumper pin placement to make a slave of a DiamondMax Plus 9, 80GB hard drive?
The manual is linked below and section 3.3.1 covers jumper settings.
The slave setting shows the park position so you have a jumper on the drive so you can reconfigure it later.
A quick answer is that the slave setting is no jumper at all on the jumper pins.
DiamondMax Plus 9 Manual - DiamondMaxPlus 9.book
Feb 12, 2011 | Maxtor Hard Drive
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Jumper settings
25870e5.jpgCheck this diagram. it shows all configuration in detail..
good luck!!
Jan 02, 2010 | Maxtor Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
5T020h2 jumper setup
No jumper is used on the J50 pins, when using the Maxtor 5T020H2 IDE harddrive, as a Slave harddrive.
In otherwords do not use a jumper on any of the jumper pins.
This is a PDF file of the Harddrive Specifications of the 5T020H2, 5T010H1, 5T030H3, 5T040H4, and 5T060H6 Maxtor IDE harddrives,
from Seagate. (Seagate bought out Maxtor)
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/dm_plus_60_ultra_ata_manual.pdf
The Jumper Settings are in Chapter 2, Page 5 (2-5)
Looking at the page number for the PDF file it's on Page 15.
Oct 07, 2009 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
