Question about Magellan Roadmate 760 GPS Receiver
Magellan roadmap 760
Its take too long to lock satellete and sometime more then 15 minutes to gave me direction
    Scholar:
  • 59 Answers
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
Posted on Jun 20, 2009
  • 864 Answers
The Magellan 760 does sometimes take a long time to acquire the satellites.  Make sure the antenna is up and has a clear view of the sky.  There are 3 GPS-related diagnostics (described on pages 96 & 97 of the manual).  Press the Options button then select Configuration and then select Diagnostics to access them. They are : GPS Status, Initialize GPS, and Set GPS Position.  GPS Status shows you what satellites are being tracked.  Initialize GPS is a reset procedure (like rebooting a computer) that will try from scratch to locate the satellites.  Set GPS position will help the unit to know which satellites it should be looking for from your current location and may speed up the process of acquiring the signals.
Posted on May 27, 2009
No signal in two units, did reset with magellan tech service, still gets stuck in the same location and no signal
Plug it in, turn it on and let it sit out in the open. If the unit is working at all, it will eventually find and lock onto the satellites. The 760 I'm using now came from California and it took over 2 hours to lock on. When I start a trip now, I let it sit before starting to drive and it locks on in just a few minutes.
Oct 27, 2009 | Magellan Roadmate 760 GPS Receiver
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan roadmate 760 gps receiver needs european lock code. This model is no longer supported and Magellan no longer sells this code.
unfortunately you have to purchase the unlock code from magellan. You contacted magellan and the unit is no longer able to be unlocked? Once I have more information I can assist you further.
Thank you,
lee
Jan 09, 2009 | Magellan GPS
Magellan 760 does not find satellites
I recently i had the same issue. Open the four screws from back. remove the back cover carefully (tahe care of the attached cables).
check the atena wire connection (gray thin wire). both the ends should be seated firmly.
in my case, soldering at one end was broken. had to resolder. its working now.
Nov 04, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 map update problem
Just push the antenna firmly back into the base; it pivots on a coax connector.
This is typical when you drop it.
The antenna is removable.
May 24, 2008 | Magellan Roadmate 760 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan 2007 map updates
it just happened with my 800 ,what i did i called magellan i gave them my bad authorization code and 24-48 hrs they will give you a new one by email.but it might be correct code with incorrect version cd,happened to me and they send it overnight with a note saying that they are sorry they gave the wrong disc.but when i put it in it work and download with no problems.so call them up.
Dec 15, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan GPS Roadmate 760
Are you willing to part with it, I may be able to use it for parts denisdsouza@hotmail.com
Aug 05, 2007 | Magellan RoadMate 700 GPS Receiver
MAgellan Rodmate 760
You should return it and get another one.
Jun 15, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 Freezes and Restarts
Chgorose, It sounds like the hard-drive is for lack of a (better)technical term.. crapping out on you. You tried the "GPS data reset" but in that same menu ("secret menu") there's another option that says reset user data (not GPS). I would try this before paying for repairs. If you have software that you can reload then reload the software as it could either be a software issue or hardware (hard drive) issue. As far as a recommendation for future GPS purchases under $600, I'm bias towards Magellan's simply because I've worked on them before and know them. Although the 6000T is nice I do believe it is still above $600, but if I was to get one I'd go for the MRM800 or 860T. Hope this helps. -Daniel
Jun 04, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
617 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
