Question about Panasonic Lumix DMC-LS70 Digital Camera
Important photos are stuck in the internal memory of my camera.
Panasonic DMC-LS70 camera.
Can I move them to a memory card?
Is there a data cable available to put them directly from my camera to my computer?
There is a tiny v.out/digital port on the camera.
Select the Display mode with the top dial. Press the Set button to bring up the menus. Press the Rev key to scroll down through the menus. On the second page of menus, select the Copy menu. Then press the Lightning Bolt key to scroll right. Select the top of the 2 menu items. This will copy the internal pics to the memory card, assuming you have a memory card inserted.
Posted on Dec 27, 2012
I took pictures without the card in. Now have pictures stored in the internal memory. How do I transfer them to the memory card?
Posted on Mar 27, 2011
My memory card is definatly unlocked however any pictures I take will still only save to in built memory. Nor can I view any photos on the memory card.Had the camera for 3 years and it has never done this....
Try this....with no card in the camera, go into the menu and find "format"..follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Jul 14, 2011 | Panasonic Lumix DMC-LS70 Digital Camera
Can't download photos...
The easiest way to transfer the pictures onto your computer is to remove the memory card and plug it into a card reader (either built in or a USB card reader if you have one). If not, you can connect your camera to your computer by the USB cable.
Once you plug the camera or the card in, Windows will usually ask you if you want to import the images. You can do that or import them manually by opening up the SD card or camera in my computer and dragging the files to the folder you want to store them in.
Please leave feedback if this was helpful. Thanks
Apr 05, 2011 | Panasonic Lumix DMC-LS70 Digital Camera
Hi, when i put in my memory card for my camera (DMC-LS70) it says "memory card is locked" how do i unlock it this never happend before.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Oct 24, 2010 | Panasonic Lumix DMC-LS70 Digital Camera
How do i down load films from my camers
If you have your driver cd install it.If you have the Data cable for your camcorder.Connect your camcorder with data cable and another end to the computer.Or remove your memory card to computer with memory card reader.Then you can import your photos to computer.
Sep 06, 2010 | Panasonic Lumix DMC-FS20S Digital Camera
Windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
May 02, 2010 | Panasonic Lumix DMC-LS70 Digital Camera
My panasonic lumix dmc-fx33 is having a problem. after taking out the memory card from the cable and place it back into the camera, all the pictures were all gone. and it says reading error, which...
The memory card has corrupted the images somehow. The recovery is a 50-50 chance. Try to find a software named rescue disk from Sandisk. And try to recover the files.
May 01, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
HI! Where can i find software for the Lumix DMC-LS70 to download photos to a Mac? Thanks.........
Hi. The Panasonic software does not work on Mac.
Here is Panasonic full list of AV software.
Your camera will be automatically detected by the Mac, only instead of using Panasonic Simple Viewer Software (part of Pana Photo Suite), the Mac will ask you if you want to view pictures.
You will also find the camera detected on the Mac as an external disk,
below a simple guide for your camera.
How can I see JPEG format pictures on my computer by connecting my camera via a USB connection cable?
Nov 15, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
My Memory card is locked how do I unlock it? Its a Panasonic DMC LS70
On the side of the SD memory card you will find a small sliding switch. It sounds like the switch is in the "lock" position. This is used to prevent accidental erasing of pictures, but it doesn't allow to shoot any either. Remove the card and move the switch away from the lock position and you should be good to go. If this solves the problem, please rate the answer favorably. Thanks
Nov 07, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Photos stuck on integral memory?
When viewing pictures, select the 'Menu' option. Scroll down and on the second page there's a 'copy' function that can either transfer photos from internal memory to a memory card or vice versa.
I didn't know this was possible until today, either. Handy!
Dec 04, 2007 | Panasonic Lumix DMC-LZ3 Digital Camera
Panasonic Lumix DMC-LS70 Digital Camera Logo
522 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
