Question about Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl
In-sink aerator makes buzzing noice and wont work even after pressing the reset button.
Buzzing like it is jammed but the blade turns freely. It is only a couple years old Insinkerator. How to handle this issue?
  • sivat3991 May 27, 2009
    You are perfect about the comment. Blade was tight and I was trying someother spot. using CRV 1/4 allen wrench I was able to loosen from bottom and it started working.
    Thanks a lot for your very prompt help.
    Sniper:
  • 69 Answers
Are you sure the blade is turning? If its not, there is a hole in the bottom you can fit an allen wrench into to turn the motor and break it free again.
Posted on May 27, 2009
    Sergeant:
  • 107 Answers
I would try getting the blades to start moving. I used to have this issue all of the time in my college housing. Fortunately, we has easy access to plumbing services and were able to get the handymen on the scene quickly to get it taken care of. If there's anything that I learned during that time it is that there are some things that should not get put down the drain. http://absolutelyclearsewersandplumbing.net/Services
Posted on Sep 03, 2015
Le Pan TC 970 9 7 Inch Android Tablet not working
Try holding the power button AND pressing the reset button. Don't continuously press the reset, just click it once.
Jun 16, 2013 | iStyles Nesting Le Pan TC 970 9.7-inch...
The garbage disposal turns on, but the blades are not rotating. It sounds like the motor is not turning over.
Use wood stick or broom handle and see if blades rotate freely.
If blades are stuck, then use wood stick to wedge free the blades.
If blades rotate freely and disposal doesn't work, then disposal has gone bad.
Install new one.
For replacement instructions:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jan 29, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water drains fine the unit runs but does not get rid of food
Be aware that your selected object you have a problem with is a hot water faucet made by insinkerator, not a disposer. I'm not sure what your problem is, but let's try to address the most common problems.
The disposer must be turned on and run to get rid of food. Does the motor come on when you turn it on? If it doesn't, does the disposer make a humming sound when you turn it on like it's jammed? If it makes no humming sound when you turn it on, first press the reset button on the bottom firmly. If the disposer then makes a humming sound, it's jammed. Read below. If the disposer still doesn't act like it has power when you turn it on, check the circuit breaker or fuse and try the reset button again. If none of this so far works and you still don't even hear it making the motor-stalled-buzzing-sound (open the cabinet door) then you should still check the disposer to see if it's jammed.
First, make sure you TURN OFF THE POWER to the disposer with the circuit breaker or fuse box. Now you need to check if the shaft rotates freely. On most disposers, there's a hole in the center of the bottom of the unit. You can insert a special disposer wrench or allen wrench into this hole and turn the shaft of the motor. It should rotate freely. You'll probably find the disposer wrench taped under the sink, or you can pick one up at a hardware store. If the disposer doesn't have this hole on the bottom, you need to go from the top. Remove the splash guard (black flappy thing) if it is removable on your model. Look inside with a flashlight for anything foreign that may be causing a jam like bottle caps. Place a broom handle against one of the lugs mounted on the wheel, and see if the wheel turns freely. If it doesn't, try to work it back and forth until it does. Then use tongs to remove the foreign object. After you clear a jam, it may be necessary to push the reset button again. If the motor became overheated it may take it as much as like 20 minutes for the motor to cool enough to allow you to reset.
Be aware that food usually needs to be pushed into the disposer manually, with a full flow of cold water.
Dec 09, 2009 | Dynamic In Sink Erator 41746 HOT-1...
KA KAdette 250 - I hit the switch the other day and nothing happened. I checked the circuit breaker - ok. I also checked the small breaker button on the bottom of the disposal. It is at least 12-years old....
12 years is middle aged for an appliance, but the problem is probably one of the garbage disposal big three: a tripped circuit breaker, a tripped reset button, or a jammed disposer. With the breaker turned off, make sure the disposer's shaft rotates freely. On most disposers there's a hole in the bottom middle where you can insert an allen wrench that you're probably find under the sink and rotate the shaft manually to free jams. But, for the love of God, only do this with the breaker turned off and make sure you remove the wrench (or broom handle if you have to go from the top) from the disposer before turning it on. Make sure the reset is pushed down until it clicks if it's tripped, and, since circuit breakers get old and stick, you'll have to turn the breaker all the way off and back on to make sure it's not tripped. If the disposer hums but doesn't turn when you turn it on, check to see if it's jammed. If it turns freely but hums and doesn't start then the starter circuit on the motor is bad. If the breaker and reset button are ok and it doesn't even hum when you turn it on, you'd want to check the disposer to make sure it's getting power. You can find a little electrical reader at walmart for $5 that works like a geiger counter and will beep when it gets close to something that's receiving power. The switch may be worn out, but really the disposer's motor failing is probably the least likely thing. But please get a qualified electrician out there if you don't know what you're doing. There's a reason that it requires a license.
Oct 25, 2009 | KitchenAid Home
Kitchenaid kadette 250 1/2 hp won't turn on.
Try turning off the circuit breaker and turning it back on, pushing the reset button firmly on the bottom of the disposer, and checking to make sure it's not jammed and rotates freely. If it is jammed you can put a disposer wrench or allen wrench in the hole in the bottom and rotate the shaft to free it. There might already be a wrench under your sink for that.
Oct 23, 2009 | KitchenAid Home
Humms but blades don't move. the blades move freely. the reset button did not fix it. thank you.
Try placing the allen wrench into the socket on the underside of the disposer and working it back and forth, then trying it electrically. The blades can appear to be free, even with a jam. The moving of the inner workings with the allen wrench should free it all up. Flush the disposer with a potful of ice and water when it turns freely.
Best regards, --W/D--
Aug 12, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I turned on the wall swithch. there is a buzzing noise but no movement. blades move freely when i hand turn them. i have unpluged the unit from the wall, still no movement
I think you are talking about a disposal. Since the blades move freely and you have actually unplugged it from the wall, feel all around the bottom of it for a reset button. Even if you have removed power, if this button clicks when you push it, it was tripped. Otherwise, my disposal just did the same thing. The type I have only last for 2 years. Mine buzzes and thats all. The motor has gone out. I will have to replace mine. You may as well.
Jun 10, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Garbage disposal won't turn on
Three points to ck. !) make sure disposer is plugged in under ther the sink. 2) Make sure the circuit breaker at the breaker panel has not tripped. 3) Make sure disposal is off and make sure it is not jammed, 3) Press reset breaker located on bottom of unit (red button.) Then try wall switch again.
May 20, 2009 | KitchenAid KSU90S0MLL 16" Undermount...
Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
1,368 people viewed this question
Top Buck Home Experts
Donni Steen
Gene Haynes
handygirl911
handygirl911
Are you a Buck Home Expert? Answer questions, earn points and help others
