Question about Sony Cyber-shot DSC-W35 Digital Camera
Access Probelm with DSC-W50 camera
I receive "access" error when I turn on my camera. The lens continually tries to open and close. This repeats until I get a message: to power off and restart again. I tried that many times with no success. I change my battery with no success. I changed my memory stick also without any success. I have tried to do a reset, however I cannot get access to any function keys to begin the reset function My daughter had same problem with her Cyber-shot several years ago too, but her camera was unfixable. Is there any way to diagnose this problem. I dont want to spend about $75 to have a Sony authorized dealer tell me that the camera is not fixable (of course the camera fell out of warranty about 5 or 6 months ago). I have also heard that this situation is fixable if you take the camera cover off. Is this true? Thanks. I receive "access" error when I turn on my camera. The lens continually tries to open and close. This repeats until I get a message: to power off and restart again. I tried that many times with no success.I can not use any functions because of that My camera is not even an year old Please help me as i need to go holiday in 2 days Regards Hitu the lens stuck and when the camera doesn't start up ... any advice please
Abrakati,i have the same problem,still unsolved.however,to access the menu i depressed the button to view 'shots' taken.while in that mode i was able to access the menu but resetting did ****.i still get the same malfunction.chris.
Posted on Jun 04, 2009
I receive ''access'' error
The "Access" will stay there until your camera passes it's self lens test. The test runs 3 times, then gives up with an error message. The cause of this problem is most likely a grain of sand somewhere in the lens. Only a camera tech could possibly ever hope to find it. Replace the camera lens.
Nov 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Turn on but not working
Most all cameras have a "FORMAT" mode that is accessable through your MENU options. Find It and try RE FORMATING YOUR CAMERA. You may lose stored images but it will reset the Camera back to Factory settings. Good Luck
Oct 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Cyber-shot DSC-W50 Camera help
When i turn my camera on, the lens try to open but it dosen't.It gives me error message 'access' then it says turn off the camera then on, and when i do that nothing changes,help.
Sep 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Digital Camera Fault
ACCESS error could happen when lens gets stuck but if it happens when lens moves back and forth without problem it usually means that where the lens assembly plugs into main system board connection is loose. These connections are held in place by a very small thin fragile plastic clip and a few drops could be enough to snap it but not do any other noticeable damage to camera. Camera would need to be opened to see if clip is broken or maybe cable just needs to me reinserted. Either way only open camera if no longer under warranty and you are somewhat handy
Mar 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
well well well a simple way to fix it if u r scraed to whack thn tap the lens,menu part ,sides wid a pensil or a pen...bit little harder atlest d cam should get little vibrations well it really works...belive even i had d same problem just after 15days just d previos day to a holiday...thn i just tapped itwid ma fingure n u wont belive it worked...
Feb 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Lens gone crazy pops in and out repeatedly
sounds dumb, i've had similar issues when accidentally taking the memory card when the camera is powering up or down. have you tried to reset the camera with/without memory card?
Jan 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
The soluction not working
Tap side of camera with base of hand with 2 or 3 sharp taps.  Then turn camera on.  Problem should be solved.
Oct 18, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
This soluction not working
Hi REYPERLA
I`m afraid resetting the camera will not work. The camera has a lens problem and is therefore giving the error.
Contacting your nearest Sony service centre is your only solution.
Sorry about the bad news : (
Dawiem
Access problem with DSC-W50
It's a problem with the lens. Usually, the internal focus lens jams up, or is out of alignment. It has to be opened up to be fixed, and the lens might have to be replaced. Occasionally, you can give the camera a good whack in your hand while it's powering up. Just be very careful not to hit the lens, or the LCD; as they can be permanantly damaged. Hit it with your palm on the corner, or edge. Also be sure the camera doesn't fly out of your hand...then it, or something will break, obviously.
Sep 06, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot (DSC-W50) Access Problem
did you try to reset the camera or call sony?
Aug 31, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot  DSC-W35 Digital Camera Logo
261 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
