Question about Kodak Easyshare Printer G600 Thermo Printer
Kodak #G600 printer dock/roller won't pull paper through
Just replaced ink cartridge and using the correct Kodak paper. Error messages include "no paper - paper jam (there is no paper jammed in it, though) and it has also said wrong paper - turn off and restart".
Printer dock is less than 3 years old and since I just bought a new cartridge at $25 I hate to just go buy another printer. Also I can not seem to find any store that carries either the Kodak #G600 or G640 so that I could still use the ink cartridge I just bought.
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
Posted on May 28, 2009
I have a kodak g610 printer dock and the paper is not being taken into the printer correctly and the printer keeps sending a message to unplug for 10 seconds and try again, any ideas
-Try to Unplug power cable for 10secs
-Remove paper try from the printer
-Make sure you are using the extralife paper or the thermal paper that came from the cartridge
-before you put the paper tray on the printer clean first all the rollers of the printer using a clean cloth
-Now if your done put it back now the paper tray
-Plug the power cable back
-Then do a test print.
If these solutions did not solve the issue please call kodak toll free 1 800 235 6325 and have it repair. GudlucK
Nov 02, 2009 | Kodak EASYSHARE G610 Thermal Printer
G600 printer dock used about 6 months ago. Only
Yes, maybe the ink dry out. Try a deep cleaning several times, from the printer options.
If you don't use the printer, you should weekly print a test page to avoid this problem.
Aug 27, 2009 | Kodak Easyshare Printer G600 Thermo...
The dock doesn't grab the paper. and if i help it, it just jams up
I had the same problem. Kodak support advised to take a damp lint free cloth ( I used a white handkerchief ) and wipe clean the center roller that grabs the paper. You can rotate the roller manually until you're satisfied you've cleaned it all. I just wiped it right to left several times and all was ok again. I didn't see any residue at all on the handkerchief but there must have been something that was there. Anyway, I think this'll work for you also.
Now if I could only figure out why my printer dock plus is only printing the lower part of pictures even though I installed new ink cartridge. Kodak advised to tighten slack in cartridge. There was not any noticeable slack. Still a no go.
May 17, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Can't remove used ink cartridge from G600 Printer dock???
I found a how to video on the web.Turn off your printer. Hold down the left arrow button and transfer button at the same time, then turn your printer back on. You should hear it make some noises, open side door push on cartridge to see that it is locked in. Then hit the green release button on the inside and the cartridge should come out on its own.
Mar 20, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Hold the transfer button down then hold the left arrow. Make sure the printer is on. Should here some clicking noise. When it completes then remove the ink cartridge.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
Have kodak easyshare g600 printer dock
Here is how I solved this problem. If you pull out the paper tray, you will notice two small, white, push pins under and to the right of the pinch rollers. Dip a cotton swab in isopropyl alcohol and use the swab to push each pin in and out a few times, thus cleaning the pins and the holes that guide them. Give it all a minute to dry and reinstall the paper tray.
Dec 14, 2007 | Kodak EasyShare Color Photo Printer Dock
Kodak Easyshare Printer G600 Thermo Printer Logo
1,047 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
