Question about Dryers
Broken Kenmore 80 Series dryer
Hello I have a Kenmore clothes dryer (80 series) Model# 110.72812101  and it having a problem,the motor is working and the heat is coming in the dryer but the part where the clothes go to get dry is not turning ,what could be the problem ? and what can I do to fix this problem? I would be very grateful for your help ,I cannot afford to buy a new one at this time so I would like to fix this one with your help of course ,thank you so much.and have a great day.
  • 1 more comment
  • Anonymous Feb 18, 2008
    HOW DO YOU INSTALL A NEW DRYER BELT ?
  • Anonymous May 03, 2008
    i have checked all eletric conections
  • phillyman26 Oct 22, 2008
    the pulley system seems damage i would love to know what it looks like to see if i can fix it do you have photos.
I sent a exact comment to other guy and response were much different ,I got all the information I wanted including part number and I even already order my part to fix it so thank you and next time you should not be so blunt.
Posted on Oct 23, 2007
  • 5,911 Answers
Sounds like you have a simple broken belt problem.  If you are sure the motor is working and the heating circuits are functioning, but the drum does not turn, the drum belt probably broke.  They are inexpensive to replace and are carried by almost any appliance repair store.
Posted on Oct 21, 2007
  • Jeff Rockwell
    Jeff Rockwell Oct 22, 2007
    Could you please post back with comments as to what you might have done to solve the problem yourself instead of just leaving a  negative rating with no comments.  You asked some very simple questions and I gave gave a simple response.  The only thing left that turns a dryer drum if the motor is working properly is the BELT.  It would be nice to know if you had any further questions like, "How do you take the dryer apart?", or, "Where is the belt located?", or, "How do you install a new belt?".
I HAVE A KENMORE 80 SERIES GAS DRYER. IT WORKS
Yes the moister sensor is at fault
Apr 29, 2010 | Dryers
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Dryers Logo
365 people viewed this question
Top Dryers Experts
