Question about Troy Bilt Tb70ss Gas Trimmer
Will stop running when the triger is pulled
I have a troy bilt tb75ss line trimmer I move red flag start engine but as soon as I pull the trigger it will stop. help please Thanks
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
#1 Taper
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
  • 127 Answers
SOURCE: replacing pull cord on 4 cycle gas trimmer, troy bilt
these usually are threaded counter clockwise need a pair of channel locks to hold the flywheel then with the other hand crack nut open
Posted on Jun 30, 2009
  • 76 Answers
SOURCE: I have a troy-bilt TB514CS 4 cycle gasoline
You need to recoil the spring.
Posted on Apr 09, 2011
Testimonial: "Thanks"
How do I fix a surging Tecumseh engine on my 1988 Troy-bilt rotor tiller?
Clogged fuel inlet line or fuel filter. It's not getting enough fuel to run
May 09, 2015 | Troy-Bilt Garden
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
Most 2 cycle engines have 3 choke setting. Place it in 1 and pull until I starts then it will die. Then place in 2 and pull again. It should start and run a little rough for a few seconds. Once it is running flip it to 3 and go. If it still dies when you give it gas try running in the #2 position. The problem is the air/fuel mixture is too high. Locate the screw on the carb and turn to the left to reduce the amount of gas. Hope this helps
May 06, 2012 | Troy Bilt Tb70ss Gas Trimmer
Won't start. String pull will not go more than a few inches. Engine seized?
Try the clutch. I just fixed this problem.One of the clutch springs ate it's way though the red housing where the spring for the pull start is at. When the housing came apart the engine seized and I couldn't move the pull start. For the schematic on the engine here is the web address http://www.searspartsdirect.com. Hope this helps.
Aug 20, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I can't get it started and I"m following directions on side of machine.
Those direction are not accurate all the time, I usually prime mine 4-6 times. put mine on full choke with the trigger pressed and pull 1 time any more will usually flood it, If you have the choke that kicks off after you press the trigger, put the choke back on to half and pull the cord pressing the trigger, Then pull the cord until it starts without pressing the trigger. As before if you press and hold the trigger during the start it will flood these trimmers..This should start the trimmer. You may have to let the trimmer set for about 15 min if it was flooded.
Sep 19, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
4 cycle engine wont stay running when pulling it has fresh gas
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit abd replace all appropriate parts.)
Jim
Jun 12, 2009 | Troy Bilt Tb70ss Gas Trimmer
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Wont run when you pick it up or give it gas
Make sure your fuel line, with filter has slack to move around in fuel tank.
May 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
The starter line on my trimmer will not pull at all.
Remove spark plug to see if problem is in engine or drive unit
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
380 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
