Laars Lite 2 heater issue: I am unable to reseat (screw in) the two drain plugs on the side of the heater. The threads will not catch. The screws (plugs) appear to be in good shape. Please let me know what it is they are being screwed into, if that part is replaceable, and how I would go about replacing it. Thank you.
    President:
  • 3,433 Answers
They screw into the tank and it cannot be replaced without replacing the whole shabang. BUT!!! nOT TO WORRY!!! the threads in the tank can be repaired by running a Yhread tap into the holes.Take the plugs to the hardware store and ask for two new plugs, preferably brass. And a pipe tap (npt) of the same size. 1/2 npt or 3/4 npt and a roll of teflon tapte. Don't buy a china made tap, Buy a good one. Its cheaper than a water heater. hen you use the tap don't cut new threads, just"chase" the old ones. The tap is pretty much self aligning so start by hand and turn with a small crescent wrench cleaning up the tank threads. Put a little oil on the tap threads. Just remember not to go past the point of bottoming the tap. Any further you are cutting the hole larger. Wrap the threads of the plugs with teflon tape opposit the direction you will be screwing in the plugs. The plugsshould start easily. Do not force anything. Snug them down and kick back. problem solved. Good Luck. Let me know if you need further help.
Posted on Jun 01, 2009
How to replace laars lite 2 LD250 ignitor
turn off power remove white leads from fenwall remember which goes to which on bottom in middle unscrew 5/16" screw remove install new one dont bump or it will break hook wires back up it should work
May 21, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
We bought a house last year that has a pool with a Laars Lite 2 heater. The drain plugs were not on the unit and we've tried to replace them, but it seems that either the treads are stripped or they...
We come across these from time to time and we were told that when the part is installed at the factory it is by machine...sometimes they end up so tight that removing them strips the threads. In the past we take a pipe tap out and re-thread the hole and then the new drain plugs will fit fine. It is a 1/4" MPT (often referred to as NPT on taps) pipe tap (tapered). You may find a local pool or pump service company or maybe a plumber that will lend it or make the service call to do it for a reasonable price.
John
Jun 21, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
What is the best way to remove and replace a leaking drain plug from the heater? The wing portion has broken off and the threaded brass core doesn't seem to turn even with vice grips. Any suggestions??
If the brass core has flat sides like a bolt or notched in any way then it will come out. It may have been put in with thread sealer so it will be tough. If you could push most of the water out with air, then you can heat up that brass plug and it will easily come out. If you can't get the water out then you will just need to use a large socket set or larger vice grips to clamp on enough to break it loose. If you have room to swing a hammer you should rap on the bottom of the brass plug (core) about 10 hard times. This will oven break the rust or thread lock stuff.
Sep 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Need to know where the electric supply goes in on the teledene laars epg-175
About two thirds down the right side of the heater. Inside the ignition control will have one screw that holds the mounting plate in place then it will swing out on hinges and all your wireing will be done behind it.
Jun 24, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I need help hooking my pool heater up to the power. Where do I hook it up at? model esg250n serialf94pk0417
power input feeds into right side of heater.remove door and remove 5/16 screw that holds metal cover adjacent to input opening
Jul 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lite 2, mod-lg125n, sn. d03pj3400.
sounds like heat exch is plugged.remove top of unit and inspect for nests.could also be plugged with soot because of poor burner flame characteristics.with top off,turn htr on and look straight down into unit. you should be able to clearly see burner flames between fins. if not remove exchanger and clean
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot valve will not turn
Hi do not remove the screws it will be safer to change the gas valve
Jun 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Cannot screw in plugs on side of Laars Lite 2 Pool Heater
I just had the exact problem. Went to a plumbing supply house and got a 1/4"NPT pipe tap for about $10 and a 1/4" brass pipe plug. Put some oil on the tap and very carefully clear the threads by threading it into the hole. Make sure it is straight and engaged with the threads. Once started run it in by hand until it stops and then get a small wrench and turn it about a half turn and then back a quarter turn for a couple of full turns and then remove. Inset the new brass plug
This did the trick for me, good luck.
May 24, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
