Question about Peg Perego Vespa Scooter
How to pre-mix 2-stroke
Ive just got a secondhand piaggio 50cc scooter that needs to have oil pre-mixed, ive just filled a 5litre can with petrol how much oil do i put in?
    Sniper:
  • 75 Answers
The recommended mix is 40:1. So for 5 liters of fuel you're looking at 4.2 ounces of oil.
Posted on May 27, 2009
  • Peg Perego Master
  • 706 Answers
You need 2% of 2T oil.. (only 2stroke oil-self mixing/ not motor oil)
that means for 5 liters you need exactly100ml - not more
Posted on Sep 28, 2014
How to refuel a sym jolie 50cc scooter, do you mix oil into the petrol tank, or do you fill the oil and fuel seperatley or does it mix it itself????
Pretty much all are normal petrol in the fuel tank and the oil is on another tank. The oil is mixed as it enters the inlet manifold.
Your manual is here. Section 2-3
ScooterCommunity
Nov 06, 2016 | Sym Motorcycles
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 | Garden
I have just bought a 1988 vespa px 125 under the seat there is 2 holes one for the petrol and one that says oil ive put 2 stroke oil in the oil tank and petrol in the petrol tank today i hit 50 and the...
older Vespas without separate Oil-tanks need a premix of 1:50 oil in the gasoline - but yours is an automatic oil-mixer type.
check the oil-level-glass under the seat near the choke.
it must be full of oil - the oil tank can hold about 1 liter of 2-stroke oil. How much oil did you fill in?
Probably the previous owner removed the oil supply tube and filled always an oil-gasoline premix. You better ask him about it. If the tube was removed then there was no oil supplied to your engine and it got stuck and the engine bearings are blown.
Apr 07, 2012 | 2011 Vespa GTS 125
Where does my 2 stroke oil Go in my piaggio Zip 50cc 2007
There should be a tank, usually under the seat or behind the rear side panels. Just fill the 2-stroke tank and don't worry about the mixing, the engine does it on it's own.
Feb 19, 2012 | 2007 Piaggio Zip 50
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
What 2 stroke oil is recommended for a Piaggio zip 50 2 stroke
Use 2T oil if you are mixing it with petrol.
Regards.
don't forget to rate this.
Jul 02, 2011 | Piaggio MachG LC Motorcycles
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
The person I bought it off said it takes 50 to 1 don't know how to measure that
50 to 1 means that for every 1 unit of (2 Stroke) oil you use 50 of the same units of petrol. Most 2 stroke oil bottles have a measure on the side which you use to measure how much oil you're using so for 5 Litres of petrol (approx 1 gallon) you would use 100ml of oil.
50 to 1 which is usually written as 50:1 is a very light mix. Husqvarna saws use 40:1. You need to use good quality 2 stroke oil from tool hire shops rather than the cheaper stuff you can buy at petrol service stations. Some makes of 2 stroke oil, like Stihl, have a measuring cup on them with ratios marked on the side. To fill them you take the cap off the measuring cup and fill to the mark at 50:1 by squeezing the oil bottle. Then pour that into 5 litres of petrol. You can also buy mixing bottles in some hardware stores with ratios marked on them. You fill the oil up to the mark 50:1 and then fill it up with petrol to get the right mix.
Dec 23, 2010 | Garden
Do i mix the casstrole oil with the petrol for the aprilia 125
It depends if you still have a pre mix tank already fitted. Mine came with the pre mix tank taken off. It is a white coloured container in a fairly flat shape on the 98 model which should be underneath the seat when you lift it. Not sure about newer models. It should have 2 stroke oil in (quite often pink). If not I have been advised to mix the 2 stroke with the petrol at about 50:1 ratio, however I would check with your local motorcycle shop or Aprilia dealer. Alternatively get a workshop manual for the correct year of bike and it will give you all the information you need in there. Also if the tank runs to empty it has to be bled otherwise if air is in the pre mix tank it can cause damage to the engine.
May 01, 2010 | 2003 Aprilia RS 125
Peg Perego Vespa Scooter Logo
672 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
