Question about Toshiba Satellite M30X-S181ST Laptop
Problem wit the music keys+dvd drive+right speaker
Ya i am having tosibha's satellite m30-106.the problem s that of the dvd drive and i hav one more problem wit the music keys .it s not working
  • brajkishorpa May 11, 2010
Which key is it to turn my internet back on
It's the little satellite dish looking button right above your F1 key.
May 17, 2012 | Acer Aspire 7736g Dvd Rw Gt30n Optical...
My altec lansing ATP3 right satellite speaker cannot operate...
Speaker is bad or the cable may have come loose. Has it been knocked around? If so it may have pulled the cable loose inside the speaker, try playing a song and wiggle the wire and push the wire in gently to see if it starts to play if it does you have found your problem. If not then the speaker is bad and I don't remember if you can pull it apart and buy a new speaker to install in it. Thanks for using Fix-ya and if this helps please rate this free question.
Avid101
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
Upgrading dvd drive
Yes pretty easy but maybe expensive a better way perhaps would be to get an external DVD/RAM and plug it in via the USB port... that way ya would have two...
Jul 29, 2008 | Toshiba Satellite A105 Notebook
No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Dvd runs cd doesnt
in your case ,this may be due to two reasons...
1)your reading lens may be having some defects like only responding to dvd`s and not cd`s
2)the cd`s that u used may have been written using digital burning security.......
try the same drive in your freinds computer also and check it out
Jan 02, 2008 | Toshiba (SD-M1002) DVD Drive
No sound
Go into the menu and choose sound check. The remote should have this as feature as well. It will play white noise on each speaker and the subwoofer. If you hear this then it is possible the DVD is not attached via optical or coaxial.
Dec 31, 2007 | Yamaha HTR-5830 Receiver
Dvd not working
Ok this type of thing is very common ... however often we chase our tails looking for a software fix when often it's the DVD/CD itself.. so to find out either way weather the device is FUNCTIONAL, download "CopytoDVD" here www.snapfiles.com/get/copy2dvd.html This has it's own ASPI recording layer... and if your DVD is FUNCTIONAL... then it WILL burn ya DVD... however if the DVD is, as I suspect, .. kaput! then it will NOT burn a DVD.. that's basically how we would "Test" Functionality. So if it works then ya all good.. else ya gonna haveta get a new DVD.
Aug 31, 2007 | Toshiba TS-L532L DVD±RW Dual Layer...
Sub issues
Would suggest that the power amp in side the speakers havs failed. Try to plug the speakers into a ipod then you can prove if tis the speakers or the Pc.
Jul 25, 2007 | Philips MMS171 Computer Speakers
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
