Question about Trident JT-306A Microphone
We need to find the range on this mic.
We need to know the mileage range on your Trident JT-306A microphone.
    President:
  • 1,138 Answers
According to http://muinstrum.com/gxnm/ the range is 100 feet.
Posted on May 30, 2009
CAN'T GET MY SHURE M58 TO SYNC
Check to make certain the mic and the receiver are on the same frequency range. The frequency range will be provided on a sticker on the mic and the receiver.
Feb 10, 2014 | Shure ULX P4 BETA 58A Professional...
Superstar 3900 eft user manual
eft is echo, freq display, talkback..
any mic can go on any radio.. just wire it correctly. and have a mic in the radios Ohm range impedance.
1. ground, 2 audio, 3 TX 4. RX not used.
so any cobra wired mic will work. or a $9 stock replacement mic. or a $39rk 56 mic. or $19 astatic mic wired for cobra/uniden. from any radio shop or truck stop.. the above are Retail prices for the temple, tx area..
Dec 10, 2013 | Radio Communications
I have a Behringer Mic C-1U and its not powering up!
How to Operate a Behringer C-1U
The Behringer C-1U is a USB condenser mic for recording individual instruments. A condenser microphone is a mic that uses vibrations produced by sound to change the distance of internal plates that produce signal. Condenser mics typically require an extra change, known as phantom power, to operate. Since the C-1U is USB powered, phantom power is not needed. The Behringer C-1U has a frequency response that favors sounds around the 10KHz range. This heightens the clarity of recorded signals due to the microphone's treble boost.
Things You'll Need:
* Computer with USB 2.0 port
* USB cable
* Recording software
Instructions
Turn on the computer. When the operating system loads, connect the microphone.
Install any necessary drivers for the C-1U. This will happen automatically when the device is connected.
Select the Behringer C-1U as an input source in any desired audio software. In Windows, click the "Volume" icon in the task bar to open the mixer. Select the C-1U as the primary input. On Macs, use the "Audio/MIDI Setup" in the "System Preferences" menu to select the C-1U as the primary input
Note: make sure you activate the phantom power on the mic. That's the only way to power up the microphone.
Have a nice day.
Feb 25, 2011 | Behringer C1U Microphone
I got a new mic and I cant get it to sync to my reciver it is a PGX4 and the mic is a PGX2
The mic is probably in a different frequency band than the receiver. Look at the stickers on the receiver and the mic to make certain they operate in the same frequency range.
Jan 23, 2011 | Shure PGX-2 Wireless Handheld Microphone...
Mic not working
On some mics, one of the lights will NOT turn on unless the battery is low. The mic is the transmitter, so I am not sure what you mean by it not lighting, but the transmitter is lighting?
Make sure the mic's freq. is within the scanned range of the receivers. Often the mics get mixed with other receivers and the resulting pair are incompatible.
The receiver should show if signal is being received. If it is, then the module in the microphone dynamic cartridge MIGHT have been damaged. If it is damaged, it has to be replaced.
Apr 27, 2010 | Shure SM58 Professional Microphone
What are the hazards a sound engineer can get from
Here is some very general info, however for more detailed info, I need more information on what your using it for. Speechs, Play, Vocals, Bands? Inside or Outside venue?
For Vocals you should have no problems with a Wireless Handheld SM58, they work over a large range, however still have a limit. Make sure the receivers are always close enough to the mics to hold a reliable connection.
Wireless Lapel Mics (Clip-on) are more troublesome, as they are generally consenser mics which are more susceptible to feedback. You also need to place them somewhere in range of the person's mouth, whist avoiding placing somewhere where you will get alot of fabric movement whist moving around, or you will hear that very loudly FOH. You also need to deal with body-packs and wires.
Leturn mics are generally easier to deal with than Lapel, however again are Condenser and more feedback prone.
I would reccomend the SM58 where possible, as it is much easier to work with, and you are more likely to get a better sound with less work.
Mar 10, 2010 | Shure SLX24/58 Wireless Microphone System...
Please send me free driver sound card trident 4dwave-dx
u can download the driver for this through this link:
http://www.computing.net/answers/windows-2000/trident-4dwavedx-sound-card-driver/2424.html
open the link and get the driver for the particular OS
Mar 02, 2010 | Trident JT-306A Microphone
Set-up wireless karaoke Mic.
I can't seem to find any technical details on the output specifications of the karaoke mic, but IF it outputs in consumer standard RCA format (a cable with two ends, one red and one white - often seen with a third yellow cable for video), then you should be able to plug it into the back of the receiver without trouble. Simply choose one of the audio connectors in the back to function as your microphone playback system - I suggest the DBS connector, unless you have a satellite system already plugged in.
Connect the Red RCA cable to the RIGHT channel port on your receiver and the White RCA cable to the LEFT channel (Red = Right). Now, select the DBS (or whatever port you plugged it into) using your receiver remote control. Hit the "ANALOG/DIGITAL" button on the remote until "ANALOG" mode is displayed.
If you want to connect the mics to a Karaoke system using the same receiver, simply unplug the White RCA cable from the Microphones, and plug in the White RCA cable from your karaoke device. Now, you'll get music playing from one side of the speakers, and mic playback from the other side, simulating the karaoke experience.
NOTE: If the microphones do not have a RCA plug on the back, please post a picture of the reverse of the Microphone receiver, and I will see what I can do to help you further.
Dec 28, 2007 | Trident JT-306A Microphone
Distortion within a certain frequency range for wireless mics on magic sing 11000
Because of the very wide dynamic range of the human voice, specially when singing, the microphone you use, needs to be smart(usually expensive) to do the job properly. When going cordless, the electronics needs to be even smarter. A windscreen will not solve the problem.
I do not know of ANY low-cost radio mic that would not frustrate you for ever and a day. Rather spend a little more and be happy.
If allowed, I can introduce you to a very budget tipe entry level radio mic, that would work much better: Beyerdynamic OPUS 168 mk2 This mic works on a diversity UHF frequancy that receives a very clear signal for at least 100 feet. It also works with a "compander" , that improves the dynamic range. You will propably pay about $300 for it, but it will last lots of years with much less frustations. Sorry, there is no inexpensive way out on this one. PA Master
Dec 22, 2007 | Magic Sing Along Consumer Microphone
Trident JT-306A Microphone Logo
60 people viewed this question
Top Trident Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Trident Audio Player and Recorder Expert? Answer questions, earn points and help others
