Question about Maytag Dryers
HEATS UP BUT DOES NOT TURN DRUM .HOW TO GET INTO CABNET TO CHANGE BELT.
HEATS BUT DO NOT TURN DRUM
    President:
  • 2,992 Answers
It probably needs a belt. Changing the belt on a dryer is a pretty simple job if you have some mechanical aptitude. The new belt is around $20 and you can save a good bit over a service call if you can try it yourself. Here is a website with good illustrated instructions as well as parts. You can also do a search on Google for "replacing belt" and your particular make and model for more information.
Posted on May 27, 2009
My kenmore electric dryer turns on and heats but the drum doesn't turn?
that would be a broken belt, or the motor, I say belt. You will need to open the top of the dryer and look in the middle of the drum for a belt, which is not there I am sure, here are some websites,Tim:
how to change belt:
http://www.ehow.com/how_4814455_change-kenmore-dryer-belt.html
belt routing Kenmore is same as Whirlpool:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.htm
May 23, 2011 | Kenmore Dryers
I need to replace the broken belt on my dryer. Its a Frigidaire Dryer Model GLGR341AS4 The model of the belt is : WCI-134163400 AB I was able to remove the cover that exposes the motor and diagnosing the...
Unplug the dryer. Using a one inch paint scraper you can locate the two spring loaded clips holding the top in place. They are located about one inch in from the top corner of the cabnet between the cabnet and the top. Depress the clips one at a time lifting on the corner of the top,tilt the top back and rest it on the wall.Inside the dryer cabnet looking down you will see two screws, one on each side holding the front panel to the cabnet. Remove the screws and tilt the front panel forward. Mark and remove the wires going to the lid switch. Remove the front panel. Remove and discard the old belt. Slide the new belt over the drum with the grooves on the belt facing the drum. Reassembe the front panel of the dryer and replace the wires onto the door switch. Replace the two screws on the front panel. Reach into the rear access panel and grasp the belt. Pinch the belt and feed it under the pully of the belt tentioner. Pull the belt tentioner towards the motor pulley and slide the pinched part of the belt over the motor pulley.
Replace the inspection panel on the rear of the dryer.
Lower the top and press down to lock it into place and your done.
Jan 21, 2010 | Dryers
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Need to change the belt, for model # LER3624JQ0
To change the belt on a whirlpool dryer first unplug the dryer
  1. Remove the lint screen and take out the two screws.
  2. Take a 1 inch paint scraper and insert it between the top and the cabnet about 2 inches from the corner to release the spring clips holding the top in place.
  3. Swing the top back and rest it against the wall.
  4. Looking down inside holding the front dryer panel on,there is a screw on both sides. Remove these screws and tilt the dryer front forward seperating the front from the dryer drum.
  5. Mark the wires going to the lid switch and remove the wires.
  6. Lift the dryer front off and out of the way.
  7. On some Whirlpool dryers there is an access door at the rear lower corner of the dryer. Remove this door and observe how the belt goes on. If the belt is broken it is easier to replace the belt if you can access it through this panel. Some newer dryers have no panel and the belt has to be replaced from the front.
  8. Remove the drum and do a complete cleaning of all lent.
  9. Check to see that the two rollers on the rear panel of the dryer turn freely. If the don't , replace them. (Clean and lubricate the shafts.
  10. Check to see if the idler pulley moves freely. If it doesn't replace.
  11. Positoin the belt over the drum where the marks are where the old belt was and put the drum into the dryer
  12. Pinch the belt and position it threw the idler pulley and over the motor shaft pulley.
  13. Reinstall the front panel with the two screws removed. Lock the top down and reinstall the two screw from under the lint screen. Reninstall the lint screen. Plug dryer in and test.
Dec 29, 2009 | Whirlpool Dryers
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
The drum will not turn on my Maytag stack dryer. It is about 12 yrs old. It heats up, and the belt looks fine
You have to lubricate the pulley bearings,and the contact surfaces and change the friction teflon element on circumferance of drum.
Vitally
May 15, 2009 | Dryers
Dryer heats up, drum won't turn. any suggestions?
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Bosch Axxis WTA 4107 Electric Dryer
Broken belt on hotpoint vtd65 tumble dryer
if it comes on and runs and has heat but the drum does not turn the belt is broken. To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Dryers
Dryers Logo
59 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
