Question about Weiser Lock Powerbolt 1000 Lock
Won't accept new code
Out of the blue, it started beeping, some long, some short.. replaced batteries with 2 successive sets of new AAs - now it won't allow new code to be entered. When number on keypad is touched, it doesn't always beep.
  • 14 Answers
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Posted on Sep 14, 2009
Thanks for your post
I contacted them and they were GREAT
Posted on Jan 23, 2010
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Medion NoteBook :LT 9886 The "Battery
The battery is shot and needs replacing.
Jun 30, 2008 | Medion Computers & Internet
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
Hi there, So, my problem is the following: My pc worked well until i changed my cpu cooler, it didint turn on, i hear only two short bips after i pushed the turn on button (during this the leds are...
Sounds like the CPU may not be seated properly, did you remove the processor when you replaced the cooler (Heatsync I assume you mean)?
Try powering down and unplugging. removing the heat sync removing the processor. Re-seating the processor making sure it falls into place. then re add the thermal paste(if needed) and heat sync. Check the memory and video card to make sure they are firmly in and then power back on and see if it will boot.
Another thing you can do is check your motherboards manual or website and there is a description of "beep codes" that you can listen for yours and see exactly what its telling you is wrong.
Good luck
Jan 24, 2011 | Gigabyte Core 2 Quad Intel X48 FSB 1600...
I use aa battery's in my camera but they only take 5 to 10 pics at a time.......is this normal or is something wrong like maybe a setting or something? what should i do to fix this?
Digital cameras in general use a lot of battery power; this one in particular is noted for short battery life. When it was new, this camera was supplied with a Lithium Ion battery for longer life; if you're using regular AAs, the battery life will be disappointing. Oh, and cheap batteries from the dollar store might not even work at all!
The most cost effective solution is probably high capacity NiMH rechargeable batteries; get a set of four so that you can have spares on hand. If even that isn't acceptable, look into getting the Lithium Ion one.
If you bought this camera used, the short battery life could easily be the reason the original owner got frustrated with it.
Jan 21, 2011 | Kodak EasyShare Z712 Digital Camera
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Alert system battery voltage low (Beep Beep)
Three possible:
1 does new battery test good?
2 is battery inserted properly (backwards)?
3 do U clean the battery holder with a pencil eraser?
May 12, 2008 | Computers & Internet
Weiser Lock Powerbolt 1000 Lock Logo
438 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
