Question about VinoTemp (VT60GNV) Wine Cooler
Cooler keeps on triggers breaker
Cooler keeps on triggering off the breaker. when I reset it it works fine for a while. obviously something is overheating or something. Please answer.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
If it is tripping the breaker, stop plugging it in. The breaker is tripping because something is wrong, and continually resetting the circuit WILL cause a fire. Either return the unit, or have an electrician look at it. You can also try plugging it into another circuit in your house to isolate the problem, but please don't repeatedly reset the breaker, there IS a problem somewhere.
Posted on May 27, 2009
Fav 60750 dishwasher has intermittent short circuit causing sparks from inner mains connector triggering house circuit breakers. No short circuit points obvious on wires or equipment. Where should I look...
It is not clear to me whether triggered fuse or differential circuit breaker?
If triggered fuse than is short circuit or overload. If triggered only differential circuit breaker than could be current leakage.
In case of short circuit I suggest you to disconnect all load, one by one (pump, motor, heating element.....etc.), until you find a load that make a short circuit.
In case of current leakage, my experience says check heating element measuring resistence between housing (earted) and each pin (two) of heating element. Should be more than 2 MOhm.
I hope I've helped.
Dado
May 26, 2014 | AEG Dishwashers
Belt stopped working
<p>If your power nozzle has a circuit breaker, then it could be bad. The eSERIES PN2E power nozzle has had many issues with the circuit breaker going bad. If the light on top the power nozzle comes on, then most likely your circuit breaker is the issue.</p>
<p>On the PN2E and PN2 Power Nozzles, it is not necessary to use the circuit breaker. If you circuit breaker goes bad, just wire the leads together and use <a href="http://www.rainvac.com/8mm-516-hole-cover-pnozzle">this hole cover</a> to complete the job. Use a 5/16 drill bit to allow the hole cover to fit.</p>
<p>The electric hose has a trigger that you turn the power nozzle on and off so there is no need to have a circuit breaker. If you get something caught in the brush roll, just release the trigger.</p>
RainVac
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
May 25, 2013 | Rainbow E series Canister Wet/Dry Vacuum
Breaker
What is this on? If it is a breaker, the grease is to coat the feed wires to keep the corrosion and resistance down
Apr 14, 2013 | Electrical Supplies
Inoperable nail gun
replace trigger , sounds like your trigger is keeping the firing valve in the open position allowing air to push the driver down, and exhausting the air out of the top, could also be that the firing valve itself is worn or broken
Aug 08, 2012 | Air Tools & Compressors
Blowing air through trigger area. Need rebuild kit? Longer version...started blowing air out of small hole in left side of casing. Leaked oil out of there as well but still worked fine. This has been...
If the trigger still works to fire the single shot, then the o-ring kit should be sufficient. If the trigger area continues to leak air, then the trigger should be replaced as well. Keep the gun well lubricated as well.
Dan
Oct 02, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I had to replace a house breaker so turned off all outside breakers including dryer. Now the dryer will run but not get hot. Is there a reset button or something that was triggered when changed breaker?
Hi, welcome to fixya. It sounds to me like your 30amp breaker for the dryer isn't fully reset. If that is the case the unit could only be running on 120v, which it will do just fine...with one exception. No heat. Turn the dryer breaker all the way off again and back "on" and give it a go. Let me know what you find, I'll be looking for your reply here. Good luck Macmarkus :)
May 20, 2010 | Roper REX3614KW Electric Dryer
I have a Ryobi RE175. It just stopped working
1. Shut the power off, and disconnect your Ryobi
router. It could be the start/stop switch. So, you
can begin checking the switch contacts using the
multi-tester. Set if at 1 x 10 Ohms. Put the probes
of the tester across the switch terminals. Pressing
the trigger on will move the tester indicator to zero
if your switch is okey. Otherwise, no moverment -
the trigger switch need replacement.
2. Should the trigger switch proved to be okey, Check
the carbon brush of the unit, short carbon brush??
you have to replace it.
Nov 03, 2009 | Electrical Supplies
Cleaning solution tank dumping
in some cases the reservoir that the tank sits on would have to be replaced. best way to tell is, if you take the tank off and pour a little water in the valve where the rubber gramet is. if it holds the water its good, but if it goes down without you pressing the trigger then it will be the reservoir.
Jul 27, 2009 | Hoover F5906-900 Upright Steam Vacuum
I have a alto pressure washer i have problem with the trigger
GO TOO WAL MART AND SEE IF THEY HAVE A COMPARABLE TRIGGER AND NOZZLE ASSY. REPLACE THE THING WITH SOMETHING DIFFERENT. WHAT YOU HAVE IS JUNK AND WON'T NEVER WORK FOR LONG.
Apr 21, 2009 | Karcher 2500 PSI Pressure Washer
The control is not triggering the machine to work
Lid switch will cause simliar problems. No spin, no agitate and will not drain water. $30.00 part and easy replacement (two screws and a plug located under lid
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
VinoTemp (VT60GNV) Wine Cooler Logo
491 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
