Question about Avaya AT&T Partner Phone
Auto attendant does not pick
I have a programme my voice mail but every time i call in i get an automated voice saying your call is being transferred to the receptionist instead of the autoattendant greeting and promt that allows the user to select an extension number to reach.Thanks
  • 1 more comment
  • wewalke May 28, 2009
    i tried the solution above it didn't work i am using partner vs 4.0 with pacs R 8.0 12e system.thanks
    #505 7 then assigned ext 30 31(voicemail extensions)
    slot 1 acs 308 expansion module,slot 2 Partner mail vs 4.0,slot 3 partner acs 509 processor
    Yep That surely did it Thanks alot now i have to continue fine tuning it thanks a million i got a print that said 30,31 oh well
What kind of phone system? If Partner, it sounds alot like you lost all your programming, so the phone system isnt programmed to know where the voicemail is. So hwen a call comes in, the ports where the voicemail is, ring, so they pick up, but dont know what they are to do with the call, so they shove it to the receptionist.
#505 needs to be programmed, then #206, that will get you to at least asnwer incoming calls.
Need to know more, like WHAT KIND OF SYSTEM.
Posted on May 27, 2009
  • Anonymous May 28, 2009
    WHen you did #505, what did you enter? What group? What extensions?
    List out teh cards in the order they are in your 5 slot carrier from left to right.
    In #505 your extensions shouyld be 31-32.
    You can verify this, by calling 31, if it is voicemail, it will say "transferring call", then transfer to 10
    Unassign extension 30 from group 7 then, and add 32.
I have Partner mail vs release 5. When someone calls in they get the receptionist voice mail(10) instead of the day menu prompt of the automated attendant. How do I get messages to go to the automated...
You are going to need to get into programming.
#206 group 7, line 01, change from "3" to 2 assigned
You need to do that for all lines. That will make it go to the Auto attendant instead of the mailbox.
Jul 16, 2010 | Avaya Lucent Partner 616 Phone
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
Help answering calls during peak call times
Yes you need the PC ASA card and not ASX,
Example: to speak to a live person dial 72 and the zero time out option sends it back to reception and it will place it on hold,
reception would need to activate a programmable button ASA button when experiencing high volume calls,
If nobody picks up it will revert to the reception or zero time out attendant with another greeting depending on what type of avaya voice mail you have?
If you have R5 vs mail or Partner mail and not a PC mail some tricks can be done.
This may not solve your answer and ring delay on day or night mode needs to be looked at.
The reality is you can delay the callers ability to get to a live person for a minute or so if they choose to hang out without a ASA card.
Send them to an unused ex port and assign the port to automated attendant two. Depending on you VM we can have up to 5 AA's and greetings.
The fact is if your receptionist can't place the call on hold with a music on hold greeting that says's Bla Bla Bla and more nice stuff and stay on the line we will be with you shortly then you need to hire a new receptionist.
Aug 08, 2009 | Avaya Lucent Partner 616 Phone
Avaya Lucent Partner Auto Attendant
Nope. You are stuck with that. If you want you can change the button that they press, to say....9 or something...make that a selector code transfer and it wont say "receptionist" any more.
Let me know I can help change the button press....
Mar 13, 2009 | Avaya Lucent Partner 616 Phone
Lucent Auto Attendant won't allow extension transfer to voice mai
OK, now you will need to log in and modify selector codes.
When you dial into vociemail, and it asks for the mailbox....
99#
1234#
It wont prompt you, but enter "9"
then is lists out the selections, with 3 being AA, so...
press 3 AA
press 1 for day
press 6 to modify menu
press the selector code (1) it probably says that its a selector code transfer or something.....
listen for the propmts and make it a "Direct extension transfer)
if you have the same problems with pressing extensions in the 20's, modify selector code 2 also.
When done entering selector codes, press star(*) pound(#)
then press pound(#), and that will save the selector codes
hang up...As long as selector codes 1 and 2 say "Direct extension transfer" you should be good.
Jan 13, 2009 | Lucent PARTNER18 Corded Phone
Panasonic 816 reduce from 4 to 1 ring before auto attendant ans.
You can voice mail to answer after one ring.
You will need a programmer to program ringing.
info@ameritelnj.com
Tony
Dec 02, 2008 | Toshiba DKT-2020 Corded Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Cant get auto attendant to turn off.
What are you trying to do. It isnt that easy to turn the Auto Attendant partially off....
Jan 17, 2008 | Avaya Magic Voice Mail Automated Attendant...
Remote Access
When you call in from the outside wait for auto attendant to answer. As soon as the "Thank you for calling" starts, press [*], and your mailbox number. If that does not work you may need to put a [#], 165 before the [*], mail box. This is assuming that most voice mail and auto attendant settings are operational and you have a Panasonic KX-TVS voice mail.
If a live person (not to be confused with the living dead) answers, have them transfer you to voice mail and do the whole [#], 165, [*], your mail box thing.
Dec 05, 2007 | Panasonic KX-T7453 Corded Phone
Lands Phones Logo
635 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
