SOURCE: instuction for canon camera SX20 IS
You can download for free the instruction manual directly from Canon here.
SOURCE: Canon PowerShot SX20 IS - will it support 16GB SD
Yes.
Testimonial: "Thank you for information. I can order new memory card 16GB SD HC Extreme"
SOURCE: I keep getting a memory
Have you tried wiping your memory cards completely? The formatting may have gotten messed up somehow so the camera can't recognize them. I would also check the contacts on both the camera and the cards to make sure they are free of dust. It could also be a problem with the cards themselves, but I find it hard to believe that they would both fail simultaneously; just to make sure, buy a brand new SD card and see if that works (it doesn't have to be big, you can probably pick up a 1 GB card for less than $10). If all of that fails, there's a pretty good chance that your card reader is bad. Considering that your camera is brand new, you should have no trouble sending that in for a warranty repair.
SOURCE: when putting the memory card
These questions are old, I hope you have found a solution to your problem if not try this. The memory card needs to be formatted. You have been deleting pictures and not formatting, in this case format the memory card. Always format and never format in the computer the programing between the camera and computer are not compatible.
