Question about Denon DRA-455 Receiver
Denon DRA-354r Wen i tune an emitter i just have noise. I can memorise the station, but no audio. I need your help
I have traced the fault to the rf amplfier transistor in the tuner "can" It is a 4 pin item with 6JK85 on the encapsulation but have been unable to source a replacement. Can anyone help?
Posted on Nov 13, 2010
My Denon Audio precision am fm DRa 435R Reciever will not stay on station very long. After about 30 or sometimes 45 minutes it get off station. I have it set to a local FM Station, 97.9 and it plays good...
OK,this is a fairly common problem with digital tuners, I get them from time to time in my shop, you see, what is happening is the voltage that's used to tune the set, usual;y stays rock solid, your device however is drifting off station due to this voltage changing, usually it is in the powers supply or the actual tuner itself. It can be bad capacitors, bad IC's, bad transistors, bad tuner module. Sometimes it maybe a "Dry Joint" too.
The only fix is either a replacement PSU or Tuner or indeed maybe both? One simply cannot tell exactly without examining the unit.
You need to take this unit into a Denon repair center and ask for a "Quote" as to costings etc. Once appraised of that one can proceed from there?
Contact a Denon head or local office and ask them there, for a referral to an authorised service center.
Jul 18, 2011 | Audio Players & Recorders
When i search radio chanel with SCAN UP of DRA-275rd radio, he stop on a near frequency but not exact frequency, so i cant to tune in a station. could you help me please?
Check on the back of the unit for a switch marked "channel step" or something similar.Usually close to the anntena socket or connection.When you find it switch it to the alternative position.This should solve your problem.
Jun 18, 2011 | Denon DRA-275R
My denon DRA-295 does not remember stations I set to memory when completely turned off. If on standby all goes well. A month after the problem mentioned above the tuner started to modulate reception and...
My better guess is a CMOS chip is either bad or there is a cold solder connection in the vicinity. If the power supply is bad, the receiver would not power up.
Nov 23, 2010 | Denon DRA-295 2 Channels Receiver
How do i hook up an ipod to a denon dra-685?
you can use a 1/8 inch female to stereo RCA adapter and plug the patch cable into one of your inputs like DVD or CD player. The signal to noise ratio on those inputs is pretty good.
Feb 03, 2010 | Denon DRA-685 Receiver
Looking for Denon dra 1025r Service &/or user manual
I have a Denon Dra-1025R operating instruction book,if this what you need and I can offer some info let me know
May 06, 2009 | Audio Players & Recorders
How do I preset radio stations on my hi-fi system?
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Apr 28, 2009 | Denon DRA-375RD Receiver
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Jun 06, 2008 | Denon DRA-455 Receiver
Tuner - When BASS it goes MONO
Did you check antenna connections?
Oct 09, 2007 | Denon DRA-395 Receiver
Denon DRA-455 Receiver Logo
151 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
