Question about Attachmate EXTRA! X-treme
Normail.dot is being used by another session when closing an Attachmate X-treme Session
Everytime I close my X-treme Session I get an error message that pops up within a few seconds that says Normal.dot is being edited by another session. Even if I don't have word opened. extra version 8 Office 2003 WXP SP3
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
This was fixed in an earlier release but the fix may have been dropped in V9. It happens even with SP2. The problem is that both Word and X-treme 9 have normal.dot template files. the solution is to rename the Attachmate Normal.DOT file.
Posted on Jun 05, 2009
I just got another remote for my acura 2002 rl. How do I program the second remote?
I believe the common process for programming Acuras should work for you. The below is the process. Good luck
1-Gather all remotes for the vehicle on hand. You only need one remote to get into program mode but all remotes must be programmed during the same session. The car will "forget" previous remotes everytime it is reprogrammed. 2-Sit in the car with all doors/trunk tightly closed. 3-Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on. 4-Listen for a quiet click, and then within 5 seconds press the "Lock" button on the remote for 1 second. 5-Turn the key to the OFF position, marked by "I" on the ignition bezel so the dash lights go off. If you hear a quiet click in the dashboard after turning switch to "I" then the entire process must be restarted. 6-Repeat three more times (for a total of 4 times). 7-Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off. 8-Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed. 9-Turn ignition completely off and remove the key. 10-Step out of car and close door. The remotes should be programmed and work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will "pop".
May 26, 2011 | 2002 Acura 3.5RL
When opening a new session of chrome after shutting down by using the closure X, I have the message "chrome didn't shut down properly" with the option to restore the session. Is there any way to get...
uninstall chrome from Add Remove programs. Go to your user profile folder within Documents and Settings. Delete the Chrome folder within Application Data. Be aware that this will clean out all of your previous bookmarks etc. Reinstall chrome from the Google Chrome website. Worked for me, History started logging straight away although it took a while for Chrome to initiate the Most Visited pages I had visited after reinstall.
Sep 21, 2010 | Google Chrome
When i start my internet explorer i get a box that says "your last session closed abrupt do you want to return to last session" how to get rid of it?
Click "NO".
Close Internet Explorer.
Open Internet Explor, and the message should be gone.
If not:
Disconnect from the Internet (both "wired" and "wireless" connections).
Click "YES".
Reconnect to the Internet.
Nov 08, 2009 | Microsoft Windows XP Home Edition
Getting a message about shadowing my session
The program you are using is telling the terminal to accept a VNC request, as it will send date on the port open for VNC. So the terminal is asking you to accept the prompt to allow a remote machine to control your session.
You can set the program to ignore the VNC ports, so it wont get prompted. Failing that you should be able to change the terminals behavior to the requests by editing the wnos.ini to not allow VNC connections. I think that can be done from there. Check on the config generator for wyse terminals on technicalhelp.de to find the correct syntax.
Jun 23, 2009 | WYSE S10 (90210501) Network Terminal
HP Officejet 5510 error "Remove & check color cartridge
Re: OfficeJet 6310 Tricolor (93/95) Cartridge Stops Working After Replacing B/W (92) CartridgeOptions
04-26-201210:27 PM
1. Remove all cartridges and turn off printer
2. Unplug printer and wait one minute
3. hold down # and 9 while plugging power cord back in.
4. Wait a few seconds, then press the power button.
5. Display should read "Full Null Reset"
6 Only install color cartridge. Close cover
7. Wait for machine to ask for black cartridge, then open cover and install black cartridge.
8. Close cover
9. Alignment page should be printed automatically.
Mar 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Power out within a few minutes of switching on and error message F61 given
Hi again,
Appreciate the review and rating of the Live Session. Hope for you to make use of FixYa sometime in the future.
Cheers.
Nov 09, 2008 | Televison & Video
Yahoo Mail closes unexpectedly
this is an issue with firefox 3 try to use firefox 2 when logging in yahoo mail, other yahoo services are ok.
Nov 07, 2008 | Yahoo Mail
1999 civic key fob reprogramming
KEYLESS ENTRY PROGRAMMING
Have all remotes for the vehicle on hand.
Make sure all the doors and rear hatch/trunk are closed during programming.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.
7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will "pop".
Oct 25, 2008 | Honda Vehicle Parts & Accessories
Error e-05 in car stereo
when burning, close the 'session' so it can be read by your player. an unclosed session gives you the option to save more files on the cd, when you finalize the session, the CD is closed.
Dec 23, 2007 | Kenwood KDC-MP232 CD Player
Computers & Internet Logo
1,085 people viewed this question
Top Attachmate Computers & Internet Experts
David Payne
David Payne
Are you an Attachmate Computer and Internet Expert? Answer questions, earn points and help others
