Fuzzy background on tv picture
I've just bought a new 32'' LCD TV but the background of scenes and fast movements causes a blurry/fuzzy picture. How can I improve this or, if I change the tv, what technical spec should I be looking for to get a great picture?
Thanks very much
  • barbarap39 May 27, 2009
    I don't have a Blu-Ray Player but your 'cause 2' is a good description of the problem I have so I will look into this. Thanks very much for your help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
This is probably a combination of 2 things. In both causes 1 and 2 below, I would suggest checking the TV with a BluRay Player with BluRay disc connected using an HDMI Cable. If you complain about this, then the TV is probably not that great. Expect a $200 jump to a better model at the least (but this depends on what you have now). Honestly, this is fairly normal and wont change much with the next TV.
CAUSE 1: Motion BLUR
Motion blur occurs when fast moving objects are displayed on LCD TVs. Basically, it takes time for the LED lights that make up the picture to turn ON and OFF, when and object shown on the TV is moving faster than the LCD TV can turn these lights ON and OFF, you see the trail left behind as the lights dim to OFF. This look like blur because you see the current image and the trail of the old images. 120HZ and 240HZ LCD TV are supposed to improve this but honestly, they are at times 300+ dollars more and not really worth it. Very little difference except in some few cases.
CAUSE 2: Digital TV
Digital signals are hit or miss. Good or BAD. If you are watching Cable, Satelite or Antenna; it is likely you are seeing some BLOCK NOISE. This block noise is caused by missing information or Noise in the video signal. This will cause the picture to Pixilate (you see blocks and things start looking blurry too). This happens with poor signals. This also happens with the HD channels when they have more information than bandwidth (more data than that have space to send it...image shoving an elephant into a VolksWagon Beetle)
Posted on May 27, 2009
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
We just bought our Dynex 32" LCD HDTV and we finally got it plugged it in. The picture is terrible. it looks fuzzy. We changed the settings with the contrast to see if that would help, but it still...
Return the thing,get a new tv replacement.The tv itself have a problems.The tv Tuner signal board that the board on the tv itself that taking in the incomming broadcasting tv signal cable have problems.
Nov 07, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Feb 25, 2010 | Vizio SV470M LCD TV
New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Jul 04, 2009 | Sanyo DP32648 32 in. LCD TV
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
36" tube tv. picture fuzzy and out of focus
It sounds like you may have a G1 intermittent short in the picture tube, which unless it is still in warranty would not be worth repairing.
Jan 02, 2007 | Philips 36PW9525C 36" TV
Open Questions:
Televison & Video Logo
790 people viewed this question
Top Televison & Video Experts
Electro Med Services...
