Question about Microsoft Xbox 360 Console
Xbox 360 probs
1 Drive does not always open/close
2 does not load, says open tray. successful load may take over 1/2 hour
3 very loud fan when it does load
  • Ferggy Dec 14, 2007
    The tray has a difficulty opening, and when a 360 game disc is inserted a screen appears displaying in all languages the "this disc must be inserted into a xbox 360 console", as if it wasn't a 360 console already. What gives?
  • shaun wool Jan 16, 2008
    my xbox 360 will not read disks and says in all languages that to play this disk u need to insert it into an xbox360 and obviously i am already putting the disk into an xbox 360 i have taken a good look at my xbx and just can`t figure it out. HELP !!!
  • 21 Answers
Just call 1800-4my-xbox
Posted on Oct 27, 2007
Bring it back
Posted on Dec 13, 2007
For the past few months I havent been able to play any games at all on my 360. D.V.D's sure,AUDIO CD'S no prob. games just don't wanna load. Sooooo... Anyhow I was surfing around looking for advice to find there is practically none! I just so happened to mention the prob. to my friends father who happens to work in a comp. store. Mind you he has never been inside a 360 and as he told me "I'm not suggesting this is the smartest thing to do BUT!" he said it sounds as if the rom is functioning properly when it searches for a format just not working smoothly. He suggested maybe opening up the rom and greaseing the sliders and worm gear witch I did with white lithium grease. When i fired it back up it still didn't work and my fans started that hard plowing hum. But after two or three times of puting in different games over the span of about two minutes ZIP ZIP ZIP...and off it took the fans slowed and it has worked flawlessly ever since. Once again I'm not telling anyone to open any part of a console. For most it would be a bad idea! dham.fab.
Posted on Nov 01, 2007
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Tip
Xbox 360 - Stuck or sticking tray fix!
If your Xbox 360 DVD drive won’t eject it can be a very simple fix.
The Samsung drive is almost always a very simple fix, if you have another drive, it may be more difficult.
To identify your drive, follow this guide:
• Remove the faceplate by firmly grasping the opening for the USB ports and pulling.
• Underneath the DVD tray there should be a small hole.
• Look at the wires in the hole to identify which drive type you have.
Red and Black Wires = Samsung Drive
Yellow Wires = LiteOn Drive
White Wires = BenQ Drive
No Wires = Hitachi Drive
SAMSUNG:
It is very common for a Samsung drive to not eject. It’s a very simple fix for this!
1. Power on your Xbox 360
3. When the Xbox 360 “tries” to eject, just simply push in on the tray cover.
That should make it eject!
If it does not, please follow the guide for the other drives below:
This requires you to disassemble your Xbox 360. IF you don’t know how, look it up on google, there are plenty of guides.
Then follow these steps:
1. Remove your Xbox 360 DVD drive from the Xbox 360
2. Turn over and remove the four screws securing the drive (6 screws if it’s a Hitachi)
3. Remove the top cover of the DVD drive.
4. Put the drive back in the Xbox 360, connect the wires, and power on your Xbox 360.
5. Once the 360 powers on, eject the drive. Most of the time it should eject normally. If it doesn’t you may have to force it.
6. Unplug the Xbox 360. If you turn it off with the power button the tray will close first, we need it open.
7. Near the front of the drive, you should now be able to see and access a small rubber band that was hidden by the tray.
8. Remove the band, lubricate and replace.
9. Replace the top cover and hook up and test.
10. If that doesn’t work, you may need a new rubber band. If you can get one of the right size, replace and test.
on May 13, 2010 | Video Game Consoles & Games
Tip
How to fix the "open tray" error on Xbox 360
When ever you have a problem with your Xbox 360 always do these steps first:
1. Turn off your Xbox 360
2. Unplug all of your cords
3. Plug your cords back in
4. Turn your Xbox 360 back on
1. Now with your Xbox 360 on open your tray.
2. Hold your tray open while you turn Xbox 360 off making sure it doesn't close.
3. Still making sure your tray doesn't close turn it back on.
4. Have fun!!!
If this does not work you will have to send it into microsoft to fix. If your warranty is up you will have to pay $150 to fix it. Otherwise it's free
on Apr 20, 2010 | Video Game Consoles & Games
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Feb 09, 2010 | Microsoft Xbox 360 Console
Brand new 360 elite will not play nba live 09 ONLY
ok , if it is giving u the open tay error , every time u try and load it , it could be a number of reasons behind it , i had the same problom , most games will play but i had 1 game that no matter how many new copys of the game i got , when i put it in my xbox the game spun 3 times and then said , open tray , like trhere was no game in the xbox, so i went 2 you tube and typed in open tray error xbox 360 and there r loads of examples on how 2 fix it , if u keep opening and closing the tray each time after it says open tray after about 6 to 7 times , it should play , but i would go 2 you tube , becase u need 2 open your disc drive 2 fix the problom.
Jan 13, 2010 | Microsoft Xbox Console
Tip
If your Xbox 360 Disc tray won't eject
SAMSUNG:
on Feb 02, 2010 | Video Game Consoles & Games
My xbox 360 wont load any of my games. It will read the disc, but then say "open tray".
i have the same prob with mine ur just going to have to open the tray close it and repeat untill it works.............sorry
Nov 16, 2009 | Microsoft Xbox 360 Console
It keeps saying open tray close tray
If the fan revs up to full speed in a few
min you got thermal prob ,
or could be lose connector on the
cd drive , but thats rare. I have seen
that only once and ihave fix 100,s
Jul 01, 2009 | Microsoft Xbox 360 Console
Wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
May 12, 2009 | Microsoft Xbox 360 Elite Console
Xbox360 tray won't read game
JUST SHAKE THE XBOX, It will start to sound really loud but will read the game... The problem starts when the tray stop closing due to a displacement from the closing motor. The laser then stops moving and gets stuck. Just shake the xbox (turned on) and that will get the laser goin...
Nov 28, 2007 | Microsoft Xbox® 360 Core System Console
Microsoft Xbox 360 Console Logo
88 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
