Question about Intel D101GGC Motherboard
WHERE TO INSTALL FRONT USB AND AUDIO CONNECTOR
GUYS TELL ME WHERE TO PLUG FRONT AUDIO AND USB PORT
  • azeem_issoco May 27, 2009
    YEAH MAN THANKS IT WAZ HELPFUL TO ME
  • Thomas Lynch May 11, 2010
    what type of tower and motherboard do you have?
    Scholar:
  • 56 Answers
This should help you. There are 2 USB headers located to the left hand side side of the board looking from the front and down. You should see 9 pins on each.. these provide 4 usb ports to front connector.
The audio connector is located towards the back, and sits just behind and between the PCI and PCI Express slots.
You can download the product guide here.
http://download.intel.com/support/motherboards/desktop/d101ggc/sb/d3458804_en1.pdf
and go to page 11/12 for the diagram.
Good luck
Posted on May 27, 2009
Headphones usb not working
try uninstalling and then re-installing it.
Plug the USB connector into an available external
USB port on your computer or laptop. On most
computers, drivers install automatically and your
headset will be ready to use.
Note: On windows, if you are prompted with the Add New Hardware Wizard, follow the steps to download and install the driver.
If you can not hear audio on your headset, adjust some or all of the following settings:
• Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
Jan 22, 2012 | Dynex Mono USB Headset with...
Has a USB connector that when I connect I can not use my Google Talk - what am I doing incorrectly? Best, Yvonne
try uninstalling and re-installing the headset. Plug the USB connector into an available external
For any audio issues:
• Restart computer.
Sep 24, 2011 | Dynex DX-840 Headset
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Unable to install drivers for my Boynq Alibi Webcam
I had the same problem, I bought it from a store with no CD! After plug the USB i have only sound with no Video.
After googling around i finally found the solution: You can try below.
1, Unplug your USB connector
2, Download the right driver from the real manufacture : http://home.eeti.com.tw/web20/drivers/IC_drivers/PCCAM_WHQL_Standard_Installshield_120308.zip
3, Unzip and install the driver.
4, After finished installation, replug the USB connector (You should plug to the different port that you used to plug before)
5, Now window XP finds the right driver and installs for you.
6, Restart your PC, then use Skype to test. It works :)
Hope this help you guys
Good luck
Dec 10, 2008 | Boynq ALIBIAIR Webcam
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Motherboard
Part / Feature Specification / Support Motherboard description
  • Motherboard manufacturer's name: MSI MS-7174
  • HP/Compaq name: Graphite-GL8E
CPU/Processor
  • Socket: 775
  • Supports the following processors
    • Pentium 4 600 series
    • Pentium 4 with HT
    • Celeron D
Front-side bus (FSB)
  • 800 MHz (Pentiums)
  • 533 MHz (Celeron D)
Chipset
  • Northbridge: i915GV
  • Southbridge: ICH6
BIOS features
  • The mainboard BIOS provides “Plug & Play” BIOS which detects the peripheral devices and expansion cards of the board automatically.
  • The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Form factor
  • Micro-ATX form factor: 9.6 in x 9.6 in
Memory
  • Dual-channel memory architecture
  • 2 x 240-pin DDR2 DIMM sockets for up to 2 GB non-ECC DDR2 533/400 SDRAM
  • Maximum HP/Compaq approved memory is 2 GB
Expansion slots
  • Three PCI
Video graphics
  • Integrated
Serial ATA
  • 2 SATA connectors
  • Each connector supports 1 serial ATA-150 disk drive
Onboard audio or audio card Integrated Intel High Definition(TM) audio (Azalia)
  • Realtek ALC 880 CODEC
  • THX certification support
  • 8-channels for Full Dolby 5.1/6.1/7.1 surround sound support with Dolby Pro Logic IIx
Onboard LAN
  • Intel 82562GT
  • 10/100Mbps Fast Ethernet LAN controller
Back panel I/O
  • One PS/2 mouse port
  • One PS/2 keyboard port
  • One VGA (monitor)
  • One Parallel
  • Four USB (2.0)
  • One IEEE 1394a
  • One RJ-45 networking port
  • Six audio ports support 8-channel Azalia audio codec
  • One S-video out
  • One SPDIF in/out
Internal connectors
  • One 24-pin ATX power connector
  • One 4-pin 12V ATX power connector
  • One IDE connector
  • Two SATA connectors
  • One floppy drive connector
  • CPU fan connector
  • PC fan connector (also known as duct or chassis fan)
  • PC indicator LEDs / power switch / reset button connector
  • Optical drive audio input
  • Auxilliary audio input (may be used for line input)
  • Front panel headphone and microphone connector
  • Two USB headers supporting up to 4 additional ports or devices
  • One IEEE 1394a header supporting one 1394a port
Jul 27, 2008 | Compaq Computers & Internet
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
No soundfrom speakers-{usb]
1.)Try connecting your speakers to another machine ? Then you can distinguish if the speaks or the cable is faulty or your sound software on your machine.
2.)install the l8est drivers for your sound card or audio device
3.)try the front usb, sides or other usb ports
4.) If your speakers also have "Jack" connectors, either try plugging into another audio port at the back of your machine or try the front audio ports
5.) Are the speakers powered on ? Is the volume on the speakers muted OR is the sound in your system on your machine muted or turned off or turned quiet ???
Apr 16, 2008 | Computers & Internet
Compaq Armada E500 PC Notebook usb port problem
If the usb connector / port is only damaged it should be a fairly easy task.
Your going to need a few screwdrivers to get the laptop open
and a soldering iron, to remove the port or ports connector(s)
from the motherboard then replace it with a new connector.
if the motherboard is damaged you would most likely have to replace the whole motherboard and that would be way too much money for a few usb ports.
the usb connector only has 4 pins
http://wolfstone.halloweenhost.com/Audio/mpg016_ConnectorUSB.bmp
Mar 30, 2008 | Compaq Armada E500 Notebook
Intel D101GGC Motherboard Logo
765 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
