2001 Dodge Dakota Logo
Posted on May 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan switch works on only one speed
2001 Dodge Dakota. How do I remove and replace?
Mike Vincent
Level 3:
Sergeant:
  • Dodge Master 358 Answers
  • Posted on May 27, 2009
Mike Vincent
Dodge Master
Level 3:
Sergeant:
Answers
358
Questions
Helped
188629
Points
1003
  1. Disconnect and isolate the battery negative cable.
  2. From the passenger foot well area, remove the two hex screws used to secure the blower motor resistor.
  3. Unplug the front blower motor resistor from the wire harness connector.
  4. Pull the front blower motor resistor and its wire harness out of the plenum panel and through the cowl plenum access hole far enough to access the wire harness connector.
  5. Remove the front blower motor resistor from the cowl plenum.
INSTALLATION
  1. Plug the blower motor resistor into the wire harness connector.
  2. Install the blower motor resistor to the cowl plenum panel by feeding the resistor and wire harness back through the cowl plenum access hole.
  3. Install and tighten the two screws that secure the resistor to the HVAC unit Tighten the screws to 2.2 Nm (20 in. lbs.) .
  4. Connect the battery negative cable
I need to replace the blower motor harness in a 2001 dodge dakota
What Steve said plus, double check your cabin air filter to make sure it's not clogged and forcing the motor to draw more amps. Also, perform a current draw test on the motor to make sure it's not drawing more amps...that'll burn up the connector
2001 DODGE DAKOTA A/C FAN NOT WORKING.I REPLACED FUSE AND RESISTOR WITH NO LUCK. HELP
First you have to figure out if you are missing power to the blower motor, or ground to the motor. The motor gets power from the key switch, and the fan switch grounds the resistor to change speed.
2answers
Heat / air cond control fan works only on high where is the problem
your control switch ,where you turn on up to high position, is bad. replace it
Heater fan not working on 2001 Dodge Dakota.. Fuses are good.
Wire between fan motor & switch disconnected or fan motor bad. Check and/or replace
2helpful
1helpful
2001 dodge dakota how do I relace the cabin fan
the blower motor resistor if i remember correctly is behind the glove box ,once u remove the glove box u should see it . make sure u check the wiring connector, i have ran into a few that has melted ..had to ret a replacement from chrysler that had a bigger supply wire. hope that helped you!!!
2helpful
Fan on heat and/or a/c won't work unless on high
Your fan speed dropping resistor is burnt out, it is located near the blower motor.
1helpful
1helpful
2answers
Heater fan only works on the two low settings.
if you have checked the switch as recommended, it is most likely to be the heater resistor which contols the diffrerent speeds. it is
normally fited near to the motor and is a squarish block with multiplug on it and coils like springs in the centre of it, look at the coils they may be burnt out.hope this helps
1helpful
Fan control knob has only two speeds, ''Off'' and ''high.'' Can knob be replaced or do I need replace complete control unit.
there is no computer control unit, what u need to replace is the fan speed control resistor module.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
