Question about Mitsubishi WS-55859 55" Rear Projection Television
Green blinking light will not go off
Electric went off last night.  Now green blinking light even after reset
will not go off.  TV can not be turned.
Model 107543
  • 3,130 Answers
You probably have bad capacitors in the DM board assy. These are going to have to be replaced. There are also surface mounted fuses, two of these inside this board. If you do not know how to solder on printed circuit boards, and work with surface mounted components, play it safe and call out a pro to assist you in this repair. Good Luck.
Posted on Oct 22, 2007
2 Suggested Answers
  • 1694 Answers
SOURCE: mitsubishi WS-55859
Check any/all fuse devices in power supply.Let me know.....T.
By the way,the tv serial # is 107543. I assume the model # is
as stated==WS-55859.
Posted on Oct 23, 2007
There are 4 capacitors in your DM Module that have been known to go bad. They are located in the metal box that is on the left side of the set looking at it from the back. The capacitors can be changed with relative ease, but if you don't have any experiance in electronics, I would advise that you have an service provider do it for you.
Apr 04, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
Green timer light wont go away
The TV is in protect mode because there is an internal fault.
The TV must be tested and repaired at component level.
Call Mitsubishi at the number listed on the user manual.
You can also read my comment explaining more on protect mode here:Why my TV does not start up and remains in...
Dec 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The input function is not working and the t.v. is on but no picture. Blank screen. Was working last night just fine we tried to hook up Xbox and when the input button was pressed screen went blank. any...
Perform Reset From Front panel of Tv, wait until green light stops blinking, set is running self diagnostic. If that doesn't work, it could be something in the DMD Panel containing the Digital Micromirror Device
Oct 10, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Last night the electric went off now my tv will not come back on all its doing it flashing a green light. my tv is a mitubishi big screen medallion model ws 55615
how many times is the led flashing or is it a continuous blink that doesnt stop? Pleaserespond to this same post and I will try to assist you with the problem.
Sep 07, 2008 | Televison & Video
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Flashing green button, won't reset or turn on
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green light
My tv did this, if you unplug it for a couple of days, plug it back in and push the reset, my light quit blinking, but it took about 1 to 2 hours
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859
Phillips tv
What does the screen looks like just before it shutsdown?
Sep 06, 2006 | Panasonic TC-29P22R 29" TV
Mitsubishi WS-55859 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
