Question about Vermont Casting VCS4017 (NG)
Will not ignite - Model CF9030
Have gas - will not ignite. Book says to order replacement electrode and lead wire. Maybe battery. What do you think? Notice that the battery is pretty pricey. Should I try the other parts first and could you order them for me?
Laurel Owens
2001 f150 the stater coil was bad I know this because I had to play with it and then it'd start I put a new one in but it still won't start any suggestions?
check the wires are correctly connected. replace the coil to distributor wire/lead. guessing the vehicle is gas/petrol.
check the distributor cap and rotor for wear/pitting, if you find excessive wear replace them, maybe the plug wires/leads also. There is not much more than this that I can suggest if you are sure that the coil was the problem in the first instance.
To check, remove a spark plug, insert the top end, in the wire/lead so that the conductor is making with the contact in the wire / lead , place the plug and lead very near, but not touching, a metal surface, then crank the engine over, or get a friend/family member to help, and observe whether a spark occurs at the plug electrode. If all is right in the ignition system you should see a healthy spark as the current earths.
If this does not happen please resubmit the query.
Nov 11, 2015 | Cars & Trucks
Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
Would like to know how leads hook up
for normal wire on gas the + wire is the hand electrode
the - terminal ( clamp )goes to earth on the job
when using gas-less wire in a mig the wires are connected in reverse
when using a stick hand piece in the mig the stick hand piece is on the + terminal , the same as gas less wire
all of this would be in your user hand book or can be down loaded for your machine
May 18, 2015 | Welding Tools
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My ryobi 350 cfm 180 mph gas backpack blower just stop andwont start again and my brother in-law said my mixture of gas to oil is not correct,less oil was mix how can i remedy the problem.
PROBLEM Engine fails to start. CAUSE - REMEDY No fuel in tank - Fill tank. Spark plug shorted or fouled - Replace spark plug. Spark plug is broken. (cracked porcelain or electrodes broken) - Replace spark plug. Ignition lead wire shorted, broken, or disconnected from spark plug - Replace lead wire or attach to spark plug. Ignition inoperative - Contact authorized service center.
Aug 21, 2011 | Ryobi Garden
The ignitor does not work. I am able to start a flame by inserting a match and then turning on the burner knob. Either first, middle or back. Is there a AA battery that is used to create a spark for the...
Your grill uses a push button piezo type of igniter. Each time you push the button you should her a click and a an electrical charge should be sent down a wire to an electrode where a spark will jump from the tip of the electrode to the nearest metal surface creating a spark to ignite the gas. The first thing to do is make sure the wire from the electrode to the igniter is actually connected to the igniter. Then make sure the wire is connected to the electrode. Make sure there are no breaks in the wires insualtion that could cause a short. Check the electrode and make sure it is held securly in place and not moving around. Check the ceramic white insualtor for breaks or cracks casuing a short. If all of this is ok, then it is most likely the igniter itself. You can get a replacement at www.minxenterprisesinc.com for $9.49 plus tax and shipping.
Jul 12, 2011 | Weber Genesis Silver B Grill
Can not get rotisserie burner to light
There may be several reasons the rotisserie burner will not light. First, the orifice to the burner itself may be clogged or partially clogged preventing gas flow. There may be a problem with the spark generator, the wire running from the spark generator to the electrode, or the electrode itself. The first thing to check is the gas flow. When you turn on the valve for the rotisserie burner you should hear and smell the gas if it is flowing. Light the rotisserie burner with a manual lighter, if it lights manually, then the gas if flowing.
The seconc thing to look for is a spark from the electrode when you turn or push, depending on the type of spark generator you have. If there is no spark, the it is most likely an ignition system problem. If you have a battery operated spark generator, replace the battery and try again. If the spark generator is a piezo, you have to repalce the spark generator. If you install a new battery, or replace the piezo spark generator, and there is still no spark, then you have to get to the wire and the electrode. Look for bare spots in the wire insulation that would cause a short. Check the electrode for a cracked or broken insualtor. In either case, the wire and/or the electrode will need to be replaced.
Jul 04, 2011 | Jenn-Air JLG7130A
No wireing diagram for igniter
If you are replacing the igniter, there are lead wires that come from the burner electrodes and connect to the terminals on the igniter. It doesn't matter which order you connect them in, they all do the same thing. There are also ground wires that run from the electrodes with round terminals on them, these connect to a bolt on the manifold with a wing nut.
Mar 17, 2011 | Fiesta Blue Ember Gas Grill
The bottom oven on my stoves cooker ignites but then constantly clicks and will not stop until the gas dial is switched off. Can any one give me a clue as to why? Thanks
As an ex stoves enginneer, the problem may be one of three faults;
1. cracked electrode, what creats the spark in the oven
2.electrode lead has melted.
3. faulty ignition generator.
Try takin the lead off the electrode and placing it in the oven flame, if this stops the clicking, then replace the electrode.
L.B
Jun 10, 2009 | Stoves Ovens
Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Jun 03, 2008 | Cooktops
Vermont Casting VCS4017 (NG) Logo
83 people viewed this question
Top Vermont Casting Grilling Experts
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Tom Chichester
Are you a Vermont Casting Grilling Expert? Answer questions, earn points and help others
