Question about Fisher and Paykel GWL11 Top Load Washer
Water leaks I have a GWL 10 US, every time the spin cycle starts, water sprays inside the cabinrt and on the floor. I have not attempted any fix. could you please help. dsn1125@comcast .net
  • darrell1125 Oct 25, 2007
    Thank you very much, you were right on the money with a partial blocked hose.
  • 64 Answers
Sounds as if the outlet pump or hose may be blocked or part blocked
Posted on Oct 21, 2007
Spins slow, does not drain and leaks a little.
SOUNDS LIKE MIGHT BE SEAL LEAKING WILL NEED TO DO BEIRINGS AND SEALS
Jun 17, 2012 | Maytag LAT2300 Top Load Washer
The water is not spinning out. the water is pouring out onto the floor when the spin cycle starts. not leaking when in wash cycle
You may have a pump that's bad. When it goes into spin cycle it assumes the water will be drained within a period of time before it goes into high speed spin. If it goes into high speed spin and the pump hasn't done it's job then you will get a bad mess, flood, water all over.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore 9380x Top Load Stacked Washer /...
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
During spin cycle water on floor from outside
SEAL IS MOST LIKELY LEAKING BETWEEN AGITATOR AND DRUM, SEALS ARE CHEAP AND DEDERGENTS OVER TIME CAN WEAR THEM OUT.
May 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
During the rinse and spin cycle, water is sprayed everwhere
There may be too much water and not enough clothes in the washer. If that is the case the water rises up the side of the tub when spinning and overflows the inner tub. Usually it goes into the outer tub but it can spurt out through bleach dispenser and run down the inside of the cabinet or hit the lid and splash out. Set water level (Xsmall, small, medium, large, Xlarge) appropriate for amount of clothes.
Aug 11, 2009 | Washing Machines
In the spin cycle water leaks onto the floor,
If the hoses at the back are not leaking, you need to check the drain hose lines, aksi check that the machine is not dripping from the inlet valve hose, or because of a leak from the door gasket.
Dec 09, 2008 | Maytag PAV3240A Top Load Washer
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Tub is leaking
You could have a crack in the pump housing. Take the back panel off the machine and run a small amount of water in it, then turn on the spin cycle and see if you can see any water spraying from the pump itself. 20 yrs is not unreasonable for most older models.
Mar 11, 2008 | Washing Machines
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel 913T soft touch dishwasher leaking
They do not have bottom seal, problem possibly is door cabinet seal or loose dispenser leaking, just had that problem woth one of those the other day
Aug 31, 2007 | Dishwashers
Fisher and Paykel GWL11 Top Load Washer Logo
56 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
