Question about Car Audio & Video
Wiring for aftermarket stereo
I have a 1991 Mercury Cougar with no stereo and lots of colored wires. I want to install a JVC aftermarket stereo but, have no idea what the colored wires go to. Please HELP!!!!!!!!
  • 72 Answers
Yellow w/black tracer is 12v+, black is negative
Blue w/red tracer is dash lite(not needed)
Get a AA battery, solder a wire to each end (this is called a "popper") Use this to find which speaker wire goes to what speaker, by connecting one wire from the AA, to one speaker wire.....and tapping the other wire from the AA to the other speaker wire. The speaker will make a "popping" noise. Mark the wire....and so on.
Posted on May 27, 2009
  • 38 Answers
If you have no idea what your doing leave it alone. Find someone at a stereo store who can do it for you at a reasonable cost. It should not be that much $25 to$30.
99 mercury cougar radio wiring diagram
1999 Mercury Cougar Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Yellow/Green
Car Radio Ground Wire: Black/Green
Car Stereo Dimmer Wire: White/Green
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
1999 Mercury Cougar Car Stereo Wiring Diagram ModifiedLife com
Feb 08, 2017 | Mercury Cougar Cars & Trucks
NEED WIRING DIAGRAM
If you are referring to installation and have the aftermarket wiring harness, The wires should be color coded. RED, YELLOW, & BLACK are power, ignition and ground. These should correspond to matching wires on the back of the head unit (CD player). Match the colored wires from the back of the unit to the same colored wires on the aftermarket harness and then connect them using wire connectors/wire nuts. Once you have them into the correct order the aftermarket harness should connect into the harness in your vehicle. I hope this answers your question =)
Nov 05, 2013 | JVC AM FM CD DET FACE CAR STEREO
Car stereo color coded wiring guide
Red = Ignition Yellow = Battery Black = Ground Blue = Remote Common For Amps The Rest Is For Speakers Green And Purple Are For The Rear Speakers White And Brown Are For Front Speakers
Mar 17, 2012 | 1991 Mercury Cougar
Hi people, so i want to install a aftermarket stereo in my 83 caddy sedan deville but i dont get the wires can somebody tell me do i need to use all the wires that the caddy has to put a after market...
Hi, please check to see if your colors match the ones below. If yes, then connect them to the aftermarket colors shown next. Assuming your factory installation has only four speakers, there should not be a lot of wires left over.
1983 Cadillac De Ville Stereo Wiring, aftermarket stereo wire
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (tape off), none
Car Stereo Dimmer Wire: Brown (tape off), none
Car Stereo Antenna Trigger Wire: Pink, blue
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Jun 25, 2011 | Car Audio & Video
Need wire diagram for 2001 toyota tacoma for installing JVC kw-nt3hdt stereo or any advice
Hi, here are your factory wire colors/functions. Aftermarket stereos have a common set of colors, which should be in your installation diagram. The process is simplified if you purchase a wiring adapter for your vehicle. These are available for under $10 at most WALMARTs and auto parts stores or about any place that sells car stereos. In either case, I recommend you solder the connections or at least use crimp terminals. If you have any more questions, please let me know--I've done a lot of stereo installations.
2001 Toyota Tacoma Car Stereo Installation Guide
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jan 07, 2011 | 2001 Toyota Tacoma
Put subwoofers and an aftermarket stereo in my cougar and the radio shut off and will not work anymore
On the power wire to your radio is an inline fuse. Have you checked that?
Jan 04, 2011 | 1993 Mercury Cougar
My boyfriend is trying to install a cd player in my '94 cougar and there's this big grey wire thats taped up with the smaller colored wires. he dicided to cut the little plug thng off of the grey wire and...
Generally, the way I put an aftermarket cd-player in, is to use a new 'harness adapter' that connects to the old harness and has all of the wires color coded and labeled for easy installation of a new radio using wire nuts. I wouldn't try to cut into the existing harness, without knowing what was what.
What's the 'little plug thing' off of the grey wire?
Aug 07, 2010 | 1994 Mercury Cougar
How to find out the radio wiring harness color codes on a 1997 mercury cougar
hi
1997 Mercury Cougar Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Black/Orange
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Green
Car Stereo Amp Trigger Wire: Dark Blue
Car Audio Front Speakers Size: 5′ x 7′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 5′ x 7′
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Pink/Light Blue
Right Rear Speaker Negative Wire (-): Brown/Pink
Jul 11, 2010 | 1997 Mercury Cougar XR7
Car Audio & Video Logo
96 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
