Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
My refrigerator is too cold - freezes drinks, salads
My Samsung RF266AASH bottom freezer/french door refrigerator is too cold. The freezer section appears to be working correctly, but the refrigerator section is too cold. The temp reads 42 on the unit (where you set/read it), but my thermometer inside reads <20. I have emptied the unit and unplugged it overnight. Re-started it this morning, and have checked the temp all day. Same problem. The freezer temp reads 4 on the unit, the thermometer in the freezer says 2-3 - no problem. Any suggestions would help. Thanks in advance. I have same problem. The refrigerator section will freeze items placed on the top shelf, but not all the time. Had thermistor (?) replaced, that didn't spve it, had the flap between the two doors replaced (tech thought doors weren't completely closing (that didn't work), so they are coming out again to take another look.
2 Suggested Answers
  • 16 Answers
SOURCE: My refrigerator is too cold
sounds like you have a defective temparture sensor
Posted on Apr 07, 2009
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
I have lg french door refrigerator lfx21976st pull cold air but does not freeze in the freezer
Inspect back panel in the freezer section. Is it covered in frost?
Feb 01, 2015 | LG Refrigerators
What should the temperature inside the refrigerator be, I have it set at 37
On the fresh food side you have it set at the proper temperature. Most thermostats have a scale from 1 to 7 or 9. If you set the thermostat at 5 this equates to about 37 degrees. Thermostat do lose sensitivity after a while and need to be replaces. The switch inside the thermostat wears out and the sensing bulb sometimes loses the fluid inside the sensor and the thermostat stops controlling temperature. So sounds like you have it set properly.
Oct 14, 2014 | LG LFX25960ST Stainless Steel French Door...
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
The refridgerator compartment is freezing all the food
What is the complete model number list in the refrigerator section?
Oct 11, 2013 | Samsung RFG299AARS Stainless Steel (285 cu...
Apr 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
Pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Feb 12, 2009 | Samsung RF265AA Bottom Freezer French Door...
Water beneath the salad bins
check the freezer section if its all frost up at the bottom part. the evaporator is freezing and transfering the coldness at the bottom part that sweats water beneath the salad bins. heater cycle is not working properly...
Feb 12, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
98 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
