Question about Kenmore Washing Machines
Water leak upon entry of water (not outflow)
Washer leaks at entry of water (not at outflow). Problem started after washing some rugs. ...Ron Johnson
  • slypp187 May 11, 2010
    is this a frontload or a top load washer?
  • 15,935 Answers
Check for blockage at the strainer (inlet side of pump)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Water leaks on floor when I use the machine
check to see if your outflow pump is leaking....mine is....
Apr 04, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Water leak upon filling at top/cabinet joint
Raise the washer top and inspect the water fill tube and the water level air hose.
You will need to set the timer to fill while you are watching for the water leak.
Feb 23, 2009 | Maytag SAV2555A Top Load Washer
Washer is leaking when draining...
Ok..so you checked al the hoses.. do you mean ALL the hoses inside the washer? or outside the washer.. chances are one of the hoses broke free durin the violent spin cycle of that over-sized rug.. and you haven't found it yet. If you have sufficient room to extend the washer out from the wall.. gain access to the inside of it from the back.. then check each and wvery hose connection/clamp to make sure they are secure.. also.. look at the pump assemby to make sure it isn't the source of the leak..then if nothing is obvious,, watch for leaks by using a flashlight and examining everything you can while it fills the tub.. Leaks are normally the easiest thiong to zero in on.. and ... try to have a few towels or wet/dry vac handy during all this.. Hope this helps...
Aug 30, 2008 | GE Washing Machines
Leak well after completion of wash cycle - Neptune Front Loader
peace,
ngafm1 at your service,
Water sprayed out of ( the leaky washers in the hot water shut off valve which need to be replaced.
They are inside all valves and wear out in time from normal use!
Or you can have a bad solder joint at the junction between the hot water shut off valve or the the pipe joint!
these washers in any shutoff valve can leak intermittently till they get worse and then leak all the time!
you should be able to stand there and watch it as you open and close the shut off valve again and again , and then stay there and watch it start leaking!
Or when you are opening it and closing the valve 4 times straight you may feel a trickle of water from the valve stem!!!!
This means washers in the valve stem need to be replaced!!!
Get a new plumber !!!!!!!!!!!!!!!!!! I'm no plumber but I do under stand this!
Bless You,
please give me a good rating here at fixya.com before you sign off!
Aug 01, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Asko Washer leak
Remove the bacpanel, and locate the leak. Be careful for moving parts, and electricity.
It may leak from the pump or from a hose or so.
Jan 15, 2008 | Asko W6441 Front Load Washer
Washer will not complete cycle
suspect something may have gone in between the inner & outer tubs& got wrapped around the drive shaft, this could account for the 'tight spot' & the water if the item has displaced the water seal. This may mean a biggish job to get the inner tub apart
Oct 16, 2007 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
