Question about Toshiba TDP-S8 Multimedia Projector
Remote not working
The projector is working fine. However, the IR receiver seems to have stopped working. I use a unversal remote and it stopped working on the projector one day. I got out the actual projector remote and it no longer works on it either. The projector works, I just have to manually press the power button on it.
Any ideas?
Thanks!
  • 1 more comment
  • chris_self May 28, 2009
    For sure batteries are not the problem.
  • chris_self May 30, 2009
    This is a home projector so I don't have access to another exact remote. Although the universal remote I have been using on it is a logitech Harmony 550 and it was programmed by the original remote with the IR beam. So I am assuming that it is just as good as the original remote...
  • chris_self May 31, 2009
    Projector
    Toshiba TDP-S8
    Remote
    Logitech Harmony 550 (Xbox 360 remote)
  • 50 Answers
Check the batteries in both remotes.
Posted on May 28, 2009
  • Douglas Jones May 28, 2009
    Is this in a school setting where there are same units? I have been thrown many times by two bad units. Do you know where there is a like unit where you can swap test ie. test your remote on their's and their remote on your's? If not give the make and model of your unit and maybe myself or someone else reading this can work something out with you.
  • Douglas Jones May 31, 2009
    Give me the make and model.
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
Remote does not function
change the batteries and make sure tere aren't any obstructions in the ir receiver. check the ir on the remote with a digital camera. it should look like a blinking white light through the viewer on the camera.
Jan 16, 2010 | 3M DMS700 DLP Projector
My tv stopped responding to the remote for some odd reason ( the remote seems fine ) how do i reset it ??
the problem is the IR Receiver in the tv needs
replacing,this is the receiver thay receives the
signal from the remote.there is no reset for
this type of problem.Also you my try new batteries in the remote and a new remote if the
IR Receiver does not repair the problem.
Sep 04, 2009 | RCA Universal Remote Control
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
DishNetwork IR Remote Control Problem
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
Apr 15, 2009 | DISH Network IR Remote Control
Remote works intermittently
Hi!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:first try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com.
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Oct 09, 2008 | Kenwood VR-407 Receiver
Onkyo TX-DS575X, remote intermittend malfunction
You have to raplace IR sensor PIC-26043TE2 or similar and should help.
Oct 08, 2008 | Onkyo TX-DS575 Receiver
Sony KF-60WE610 TV remote is acting up. Remote tests fine. DVR is also new, so that isn't the problem either. First noticed volume would not go up and down with DVR remote, but TV remote OK. Then wouldn't...
Hey Bry,
Judging by the picture of your television on Sony's site: http://esupport.sony.com/US/perl/model-home.pl?mdl=KF60WE610&LOC=3
The IR sensor is right below the Sony emblem. If you're really curious you can find a site that offers service manuals and order one. It will get you schematics and tell you exactly where everything is.
Also, if you get everything up and running and decide you need to replace your lamp, check out xl2100u-lamp.com. I haven't ordered from there yet, but it looks promising.
Jun 27, 2008 | Sony XL-2100U Projector Lamp for...
Unable to switch off projector with remote (Infocus SP4805)
A bit unusual for the projector to stop responding to the remote. Usually it follows when someone has opened the projector, they forgot to reconnect the controls from the case top which also includes the IR receiver. If it isn't that, it could be a broken IR pc board or bad connection. I've seen that.
The worst case is that the IR controller on the main board has failed and if that's the case, you'll have to live with it as the cost of a new board is very high.
Mar 13, 2008 | InFocus ScreenPlay 4805 Multimedia...
Toshiba TDP-S8 Multimedia Projector Logo
223 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
