Jvc rear projection tv
Looks like its in 3D the red and blue are not aligned correctly
  • 8,617 Answers
Need to replace the convergence ICs. Respond with the model number of your set and I will post a link where you can get the repair kit with free step by step instructions with pictures so you can do the repair yourself.
Posted on May 27, 2009
Double picture,shadowing red
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 07, 2011 | JVC AV-56WP74 56" Rear Projection...
I have a philips projection TV and it looks like a 3D screen without the 3D glasses. I tried converging the red & it is aligned with the cross hair. The blue convergence does not move. What can the...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2011 | Philips Magnavox 51MP392H Rear Projection...
My hitachi rear projection tv has one of it's colors out of alignment almost like it's been bent because it causes the blue color to be out of alignment in a curved fashion across the screen the tv worked...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 02, 2011 | Hitachi 50FX20B 50" Rear Projection...
Blue, red and green are separated and i cannot find convergence from main menu
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 22, 2010 | RCA P52939 52" Rear Projection Television
Picture red and blue shadowing
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 04, 2010 | Sony KP-53HS30 53" Rear Projection...
Blue streak across the top of the television and colors are reflecting making it look 3d
•Screen looks 3D
Jun 26, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Blue & yellow stripe on bottom of screen at first now red and green like 3d
•Screen looks 3D
Jul 08, 2010 | Philips 60PP9202 60" Rear Projection...
Unable to align cross hairs on the blue lense. Dose the lense need to be replaced?
•Screen looks 3D
May 08, 2010 | Hitachi 50UX57B 50" Rear Projection...
Colours are out
•Screen looks 3D
Mar 10, 2009 | Toshiba 42H81 42" Rear Projection...
Convergence
Then it is likely the pre-amp transistor that controls the red is shorted out.
hopefully you have extended warranty.
there is a trick to likely get them aligned anyway if this is a tube tv.
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
