Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
No picture spiral wave inthe center of the screen
Mine does the same thing , i leave it on for a few min's then off and back on and it works fine
Posted on Nov 02, 2007
Can not remove the large spiral bevel gear
The large spiral gear is pressed tightly on the spindle then held in place by a wave washer and retaining ring. After removing the retaining ring and washer, you have to use a press to push the spindle out of the gear.
Feb 06, 2013 | Makita Grinder 115mm - 9554NB
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
I have a Insignia NSL37Q10A, when you turn it on it display's
Change input device to some other like a DVD player. Look for loose contacts in RC jack, cable, sockets. Look for any jammed buttons on TV or on remote.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 03, 2012 | Insignia NS-L37Q-10A 37 in. HD-Ready LCD...
My picture faded off the screen
Need to see if you're getting high voltage. See if you have 130v dc on the collector of the horizontal output transistor.
Nov 12, 2011 | Panasonic PT-53TW53 53" Rear Projection...
No picture
Let your local TV repairman check it. Don't touch anything inside it nor open it.
May 26, 2009 | Apex Digital GB4308 43" Rear Projection...
Hitachi 43fdx11b green wave on top left/center of screen
Check your soldering.
Check the resistors - make sure none are shorted.
Make sure you did not buy fake STK chips...
Feb 15, 2009 | Sony KP-51HW40 51" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Blue wave across screen
Just click below for convergence repair kit;
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
Toshiba 50hp66 picture waves
Please describe the 'waves' and what you are watching when it happens, is it on everything? e.g. normal TV and when watching a DVD? Are the Waves a grey close pattern going diagonally across the screen for some other sort of pattern?
Jun 13, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Strange screen colours
Your degaussing circuit is not fully 'demagnetizing' the picture tube.
You can manually degauss it using a strong magnet, but it's tricky.
With a tool made for demagnetizing you simply hold it close to the center of the picture tube and using a circular motion slowly spiral outward to the outer edge of the tube, pulling the magent further away from the tube at the same time. The same can be done using a strong magnet although the results may not be perfect. You can experiment with a magnet using wiping motions as you bring the magnet closer to and further away from the tube.
Mar 05, 2008 | Beko 324250WN 28" TV
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
