Question about Xerox Phaser 8560MFP Laser Printer
Code 36.1 the printer was working fine but suddenly came up with - disk failure and code 36.1. Is there anything we can do??? This is urgent - Thank you Just set up the printer, following each and every step. Then adjusted system, date etc... After restarting, the error code 36.1 came up. Is there a solution? We have the phaser 8560, at first it froze up, so i turned it off then on, and now it shows a disk error code 36.1. Also when I tried to open the provided troubleshooting link, it did not come up...What can I do...I need to print ASAP.
harry_qtech
  • 63 Answers
SOURCE: Code 36.1
If powering Off & On didnt work.
Than we need to reseat the HDD.
Follow the steps mentioned on the link:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=384,E=0000000001218712366,K=3033,Sxi=8,Solution=obj(6029)
Posted on Feb 04, 2009
SOURCE: Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Posted on Mar 18, 2009
  • 117 Answers
SOURCE: XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Posted on Apr 07, 2009
SOURCE: xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Posted on Dec 15, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
03130031-2F52 error
my printer suddenly stopped working and is showing the following error code 03130031-2F52. If anybody know how to fix it, please email me at alaevphoto@yahoo.com. thank you.
Oct 21, 2012 | Canon imagePROGRAF iPF8000 Printer
All of a sudden my MP500 gives an error code
If the carriage will come out of the right corner, you need to look inside and see if there's a paper scrap or anything blocking the purge assembly. The purge is the unit that cleans the printhead, and that error says it's not moving properly. If nothing is stuck in there, you will need to have the purge assembly replaced.
Dec 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error code 04C300 001E0000
This is an IO error. If there is a Hard Disk installed, remove it - the printer will run fine without it. If that does not solve the problem, remove the JetDirect card and run the test print. If the test print works, replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Nov 19, 2009 | HP DesignJet 1050c plus InkJet Printer
I have Nokia 1650 now all of sudden it is asking security code
If you never entered any security code then enter this code 12345 when it prompts you for a security again.
Hope this helped.
Regards
Sep 24, 2009 | Nokia 1650 Cell Phone
URGENT!! 7373 keeps turning off!
try formating the phone and memory card to formatr the phone u need a code that is *#7370#
Aug 03, 2009 | Nokia 7373 Cellular Phone
Error Code 2200 on Dell All In One Printer 942
This error code indicates a jam, try a power cycle:
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
If this does not work, there is some more information here: http://en.community.dell.com/forums/t/19244466.aspx
Mar 12, 2009 | Office Equipment & Supplies
Code 36.1
Feb 04, 2009 | Xerox Phaser 8560MFP Laser Printer
Code 36.1
That is maintenance kit fault.
Can be anything from looking in back and seeing if there is any spilled ink in back behind the tray, to the motor being mistimed.
You should have a year warranty on that product.
Sep 02, 2008 | Xerox Phaser 8560MFP Laser Printer
Konica Magicolor 5430 DL Fatal Error Code: 0300H
0300H: Polygon Motor malfunction
try restart if not helping then there can be problem with ph unit or PWB-A board
Sep 11, 2006 | Konica Minolta magicolor 5430 DL Laser...
Xerox Phaser 8560MFP Laser Printer Logo
480 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
