Question about Mitsubishi WS-55859 55" Rear Projection Television
Blinking green light
Electric went off last night.   reset does not help.  cannot restart tv
  • Anonymous Dec 11, 2007
    Power went off while we were out, came back on and got the blinking green light. As others, tried all sorts or resets w/wo power, etc. Nothing. Pulled back off cabinet. Where power cord goes in, there is a 10A fuse. Of course, it was fine. Diagram says there are at least 9 other fuses. I see them labeled on various boards but none of them are visible. I know what a fuse looks like. So either these are hard wired into the motherboard or ??? they are underside the board (why would they put them there). Every fuse is labeled on the board but the 10A fuse noted above is the only one I can find. Will leave power off for a couple days and see if anything changes....anyone know where these fuses are that are on the label in side the cabinet but not otherwise visible?
  • da-kine Dec 11, 2007
    Having same problem. Check fuse, it is fine. Tried same kinds of things with no luck as yet. Will leave it off for a couple days and see if anything changes. Nearest service is 100 miles and you have to take it there.
My tv did this, if you unplug it for a couple of days, plug it back in and push the reset, my light quit blinking, but it took about 1 to 2 hours
Posted on Oct 29, 2007
SOURCE:
BLINKING GREEN LIGHT WONT RESET TV. KEEPS BLINKING. HAD A POWER OUTAGE FOR 3 HRS LAST NIGHT. CAME ON FOR A BRIEF SECOND THEN WENT OFF AGAIN.
There are 4 capacitors in your DM Module that have been known to go bad. They are located in the metal box that is on the left side of the set looking at it from the back. The capacitors can be changed with relative ease, but if you don't have any experiance in electronics, I would advise that you have an service provider do it for you.
Apr 04, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
Green timer light wont go away
Hi.
The TV is in protect mode because there is an internal fault.
The TV must be tested and repaired at component level.
Call Mitsubishi at the number listed on the user manual.
You can also read my comment explaining more on protect mode here:Why my TV does not start up and remains in...
Dec 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV won't come on
its the problem of small electrical components on the main board gone faulty due to over use it got over heated and they r blowned out.so needs to be replaced.
Nov 25, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Last night the electric went off now my tv will not come back on all its doing it flashing a green light. my tv is a mitubishi big screen medallion model ws 55615
how many times is the led flashing or is it a continuous blink that doesnt stop? Pleaserespond to this same post and I will try to assist you with the problem.
Sep 07, 2008 | Televison & Video
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Green blinking light will not go off
You probably have bad capacitors in the DM board assy. These are going to have to be replaced. There are also surface mounted fuses, two of these inside this board. If you do not know how to solder on printed circuit boards, and work with surface mounted components, play it safe and call out a pro to assist you in this repair. Good Luck.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859
Check any/all fuse devices in power supply.Let me know.....T.
By the way,the tv serial # is 107543. I assume the model # is
as stated==WS-55859.
Mitsubishi WS-55859 55" Rear Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
