Question about Endless Summer Blue Rhino 235000 Commercial Outdoor Patio Heater - Stainless Steel Triple Dome
Propane patio heater ignition problem
Patio Heater- Endless Summer Model -Push in to light pilot works fine, but when I release and turn to ignite the main burner the pilot light goes out and the main burner fails to ignite. Any help?
  • dta5 May 27, 2009
    Thanks for the advice and information.
    I found the pilot cleaning instructions on the manufacturers web site www.bluerhino.com and just completed that. It now works like new. The thermalcouple was the next thing to try.
  • 10,865 Answers
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
Posted on May 27, 2009
  • Joe Hogan May 27, 2009
    Excellent. thanks for getting back. enjoy.
  • John Barrie
    John Barrie Feb 21, 2017
    There are 2 thermal links, 1 to the pilot light the other at the back of the heater. The 1 to the pilot light is good the other is possible bad.
The pilot seems to light but then when I turn the knob to ignite the main burner, the pilot goes out. Is there a technique to clean the igniting assembly?
let the pilot light burn for a few min and get hot after this try slowly moving the knob over to full burn. Sometimes it just need to heat up.
Feb 14, 2011 | Endless Summer 233000 Open Flame Patio...
Have Endless Summer patio heater. I got the burner to run but after 3-5 minutes the heater shuts down. Also having problems getting the unit to fire after lighting pilot light Maybe thermo coupler?
It could be the thermocouple, but you have to take the head apart to replace it. If you got the main burner to fire, then the thermocouple is probably ok. Try changing the regulator, easy to do and not to expensive. If that doesn't work, try taking the head apart and cleaning the pilot and main burner orifices, do both while you are in there. If you are not comfortable doing this, hire someone.
Oct 21, 2009 | Endless Summer 2009 Open Flame Patio...
Left Patio Heater out for winter, now won't ignite
It could be just a blockage in the pilot assembly, you have to take the head apart to find and clear the blockage. While you are in there you check for a blockage in the main burner orifice as well. If it is just a blockage, then you don't have to replace anything.
If this doesn't get the gas flowing, try replacing the regulator.
Jul 01, 2009 | Endless Summer 1501 Patio Heater
Burner will not ignite as pilot light goes out when knob is released
Are you holding the knob for 30 or more seconds,If so,Clean or replace the thermocouple/Flame sensor.
May 29, 2009 | Endless Summer (GA200209) Stainless Steel...
Patio heater ignites and stays lit with pilot. Then goes out.
Press and hold for 60 seconds and then it should stay lit (this is a safty feature on most models!)
Dec 18, 2008 | Endless Summer gwt501a Open Flame Patio...
Outdoor patio heater won't stay lit
I'm told by Charmglow that the problem is the Thermocouple. iHowever,it took me several calls to get someone to admit this. They are sending a new thermocoupler. My heater is less than a year old and under warranty--but it's a shame things like this happen.
Originally I was told it could'nt be the thermocoupler as they normally last at least 5 years.
Try it--as it may solve your problem as well.
Sep 21, 2008 | Heating & Cooling
Windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Feb 29, 2008 | Endless Summer 2009 Open Flame Patio...
Pilot lights but main burner won't
sometime if the heater has been sitting for days spiders get into the burner area or the area between the tank and the burner and make a web blocking the flow. I have taken a compressed air in a can like the ones you use for computers laptops and blow air up the shaft and around the burner wait 2 minutes then try again. Sometimes it takes 2 or 3 blowouts to work. Put the air compressor right in the little gas nozzle that comes out to light the pilot for the best results
Nov 01, 2007 | Endless Summer 2009 Open Flame Patio...
Endless Summer Blue Rhino  235000 Commercial Outdoor Patio Heater - Stainless Steel Triple Dome Logo
2,505 people viewed this question
Top Endless Summer Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Endless Summer Pool and Spa Expert? Answer questions, earn points and help others
