Question about Bosch Axxis WFL 2060 Front Load Washer
Can the bosch maxx wfl 2860 wash with only a cold water supply?
At the moment i only have a cod water supply. Will my bosch max wfl 2860 work on all settings when only using cold water supply?
Tromel står .setrefugen går ikke på en bosch WFL 2860
Posted on Jan 04, 2011
Can the wfl 2000 do just cold water washes.
Posted on Nov 28, 2013
How to fit bearings in wfl 2260 bosch max washing machine
dose drum has to come out also replace element
Mar 02, 2015 | Bosch Washing Machines
How can i remove the motor in order to cahnge the brushes? pleaseon my bosch wfl 2860 gb washing machine
The best way to do it is to disconnect the washer from the water supply and electric socket.
Lay the washer on it's side, and remove the rear cover and drive belt.
Undo the 2 screws that secure the motor in place, unplug the motor lead, and earth lead.
Prize the motor away from drum.
Change the brushes.
Please rate my solution.
Thanks.
Nov 21, 2009 | Bosch Washing Machines
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch maxx 2860 won't do a quick wash anymore
The timer sticks at one place.
Quite a common problem. The least common is the actual failure of the timer itself. It is much more commonly caused by the failure of the heater, water valve, pump, a broken wire or even a blockage in the pressure system or waste system.
Mar 20, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Is there a awy to default water temperature to COLD
unfortunately no there is no way you can alter the way the max defaults as it is programmed into the module
Dec 30, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Jan 03, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
1,165 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
