Question about Canon PIXMA iP4200 InkJet Photo Printer
Not printing black ink after replacing cartridge
I have an IP4200 and have just replaced the PGBK cartridge with a non canon cartridge. It does not give any error messages but does not print anything from this cartridge. I'm having the same problem. This is a new PGBK cartridge and nothing comes up when I print a nozzle-check. I've done the regular and deep cleaning. Anyone know what the problem might be?
  • Canon Master
  • 419 Answers
Unfortunately I have no idea which compatible cartridge you're using so it's difficult to provide a definite solution. However a few things to consider:
1. The cartridge needs to have a clear vent hole so if you haven't removed tape or a plug from a hole that was indicated in the instructions, you need to do this.
2. Try removing the cartridge and then touching the exit port on the cartridge with a Q-tip (cotton bud) to see if the ink flows to the cotton. If it doesn't you need to replace the cartridge.
3. Check the cartridge is sitting properly in the printhead.. The interface between the printhead, rubber grommet and the cartridge exit port is very important and the cartridge needs to sit in this properly.
My guess is that the compatible cartridge is not up to the job and you need to consider getting an OEM (Canon original) instead.
You may want to think about finding a refill kit and using the Durschtich (German) method of refilling using bulk ink and a chip resetter instead of compatibles.... Nifty-stuff forums have a LOT of information on this subject so it's well worth a look.
Hope that helps.
Martin
Posted on May 28, 2009
Canon PIXMA iP4200 not printing PGBK properly - only printing top 50% of PGBK grid on test page.
Man you did some awesome troubleshooting! I don't know, but it sounds like something is physically wrong with internal electronics. I'd call in the big dogs at Canon themselves.
https://www.usa.canon.com/internet/portal/us/home/contactus
Nov 17, 2016 | Canon PIXMA iP4200 InkJet Photo Printer
My PGBK ink cartridge is not printing. I just replaced it. Everything else is working fine. I have done several cleaning jobs on it and the test prints that I print don't even show PGBK or the black...
the PGBK ink cartridge might not be getting a good connection you might have to remove it and check the connections or clean the connection bars
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 21, 2011 | Canon Pixma iP4500 InkJet Printer
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
May 30, 2009 | Canon MP610 Photo All-In-One Printer
Want to print back only
In your "Orinting Options" go to advanced and choose "Black ink only"..this will use only the black cartridge.
Apr 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printing Problem
Look for ink clogged on the printer head. Run cleaning or deep cleaning after installing the new cartridge before printing. Take nozzle check print.
Apr 30, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
672 people viewed this question
old marine
old marine
