Question about Toshiba Estudio 200L Copier
Can't select 'Bypass Tray' as a print option.
I have a shared networked Gestetner P7145 printer. I installed the RPCS drivers for it on a Win2k Server box. On the Server, the printer properties box for the Gestetner shows the 'Bypass Tray' as an option that I can print to. But when I connect to the share printer from a couple WinXP PC, I do not get the option to print to/or select the 'Bypass Tray'. It does not show up. I even installed the RPCS driver onto the WinXp PC to no avail. I changed the drivers to PCL6 and still only can print to Tray 1 and Tray 2 only (no Bypass Tray is shown). Please help. Thanks in advance! Joey
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p4510/p4510en.htm
Please rate me :)
Posted on May 27, 2009
Hp deskjet 550c trying to print from network But I am on windows 7. Printer is on xp. Can't find driver or fix to run printer on network
Use my published guide to install the latest drivers for all computers on the network. It is entitled
How to Install the latest drivers for Hewlett Packard Printer!!!
The drivers need to be installed on all computers in the network.
Then once the drivers are installed all you need to do is to navigate to the Windows control panel and double click printers and faxes on the computer that the printer is connected to.
Now right click the your printer and select the option Sharing, this will allow you to share the printer on the network.
Click the lower circle to share the printer.
Then when you print from another computer on the network, be sure to select this shared printer as the printer to print to, or set this shared printer as the default printer by right clicking the printer and selecting the option to set as default printer.
Please be sure to rate this session.
Take care!
damnor01
Jun 01, 2011 | HP DeskJet 550c InkJet Printer
Ricoh Aficio 1232C rpcs When I try to print the red light appears on the printer saying 'load by pass tray' even though I have selected Auto tray. Normally the machine prints fine.
when you selected auto tray was that in the driver or microsoft settings ? microsoft settings will overide the copier settings driver. look under file then page setup to see what it is set for.
May 20, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Cannot send a p rint job to pring labels from word to bypass tray with Canon 5000 copier Click on copier properties, click on bypass tray and then ok and print. Will not print fromt he bypass tray Ideas?...
If you can copy from the bypass, you should be able to print from it. It may be a setting in the print driver. Not the one you use through windows but the one installed in the printers folder in control panel. Check that it is not set to draw 1 - it should be on AUTO. Also, the document you are using has print settings of its own - check them as they will overide the tray you select. Select from within your document file - options - printer then look through those settings and anything telling the machine to print to a particular draw will make your job go there instead of where you ask it to.
Jul 09, 2009 | Canon imageRUNNER 5000 Copier
Dsc328 will not print using a Mac
If your copier / printer does not have postscript 3 option installed, it will not print from MAC. Print a configuration page: "User tools", "Printer features" "list print" (or similar), "configuration page". Check under the heading of "printer languages"......you'll see stuff like "PCL 5c", "PCL 6", "RPCS", etc. If no "postscript 3", it is not compatible with your MAC, and you don't want to know how much that option is for your machine! Ridiculous!
Feb 25, 2009 | Gestetner DSc328 Copier
Printing from the wrong tray on the Ricoh C410 DN
these settings need to be done with the RPCS printer driver, go to properties and then custom settings from there you can tell the printer where to print from.
http://www.websitetoolbox.com/mb/copierquestions
Dec 30, 2008 | Ricoh Aficio SP C410DN Laser Printer
How to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
Cl3500n ricoh
I would re-install the RPCS driver.
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c30e/c30een.htm
Also, check the the paper thickness are correct.
RPCS
On the [Setup] tab, select [Bypass Tray] in the [Paper source tray:] list, and then select [Thick] in the [Paper type:] list
PCL 5e/6
On the [Paper] tab, select [Bypass Tray] in the [Input Tray:] list, and then select [Thick] in the [Type:] list.
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 09, 2008 | Ricoh Aficio CL3500N Laser Printer
Printing Problem - Help
n your computer, left click on START, left click on CONTROL PANEL, then left click on PRINTERS. On the PRINTERS SCREEN, RIGHT CLICK on GESTETNER icon. On the drop down menu, left click on PROPERTIES. Left click on ACCESSORIES tab. On the paper source setting, select TRAY 1 LETTER as the default paper source, left click on UPDATE, then APPLY, then OK.
May 08, 2008 | Gestetner Copier
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
727 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
