Question about Apple iPhone Smartphone
My iphone shows charging but will not charge
I Plug my charger into my 2nd gen. Iphone and it shows that it is charging then after an hour or even 3 hours i come back and it has not charges at all anyone know why this could be?
    Genius:
  • 1,550 Answers
This could be a software problem
or else the charging socket problem
it is best u take it to the apple store
Posted on May 27, 2009
Message on my iPhone shows icon for iTunes to plug in a charger. What do I do?
Charge the phone at least overnite. Sometimes a replacement phone may arrive with a totally dead battery and the charger may not be able to put out enough current to operate the phone and charge it at the same time. If you want it to charge faster use a plug in charger with an output rating of 2 amps. They usually have 2 USB outputs and can charge two devices at the same time. If you only charge one device it's a piece of cake for the charger. .
Sep 10, 2014 | Apple iPhone 4S
My IPhone will not turn on. It suddenly went off, like it powered down, but wont turn back on after a 20 minute charge...even when still plugged into charger.
Try to connect it with you PC via usb cabal...and if your PC shows that he founds device (Iphone), you will see on Iphone screen that he is start charging...after that you can put it to electicity charging, with regular adapter and charge it for 1 hour and then turn it on and it will work :) That happens when battery lose her voltage (need to be 3,7V)...Otherwise if you PC, when you connect it does not show nothing, than you have some hardware failure and you need to take you Iphone to some mobile service to fix it..
Best Regards!
Sep 05, 2013 | Cell Phones
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
Iphone won't charge
is it brand new? plug it first on your computer then after setting the phone up, it will charge with a wall charger. it could also be that you're using an incompatible charger. a higher version of an iphone, say the 3gs won't charge if you use a charger that is meant for a 2nd gen iphone or lower only.
Jul 25, 2010 | Apple iPhone 3G
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Battery
hiya,
do you plug it into a wall charger or computer?
1st make sure that if you plug it into a computer that the computer is not asleep otherwise this will not charge it
2nd make sure the pins in the phone have not gone therefore restirticing the charge
Aug 29, 2009 | Apple iPhone 3G Black Smartphone
IPHONE WON'T CHARGE!!!
the thing in the port is the actuall conductor.
Jul 16, 2009 | Apple iPhone Smartphone
Iphone not working not charging all i'm getting is the apple logo when i try to charge
Hi friend, if you not can charger with the apple's provide the plug.You can try use this fast wireless charger.It can help you fast for iPhone and fpr galaxy s6 Edge+, galaxy S7, S7 edge, note5
Hot Otao Fast Wireless Charger with Cooling Fan 2 Coil Wireless Charging
Apr 10, 2017 | Apple iPhone Smartphone
Iphone won't charge and now won't work
I left my phone charging for a few hours and it appeared not to be charging as the battery icon was staying at 10% of charge. I was confused because it had the charging icon in the upper right hand corner. If your phone is doing something similar i simply powered the phone down and turned it back on. The charge went from 10% to 100% on the display. This is what worked for me hope this helps.
Jan 22, 2008 | Apple iPhone Smartphone
My iphone doesnt charge
Hi there!
There have been some reports of iPhone chargers going bad prematurely.  The test:
  1. Connect your iPhone to your computer via the USB cable.  Does it make a little beeping noise when you connect it, and then charge up?  If so, the issue is not with your iPhone or USB cable.
  2. Next, using that same USB cable, connect it to your iPhone charger.  Do you get the same connection noise and then does it charge up?  If not, the issue is probably with the charger.
Assuming you have a faulty charger, you are still well within your 1 year warranty from Apple.  Visit an Apple store (www.apple.com/retail) Genius Bar (make your reservation online before you go, to avoid waiting around), explain the issue and how you tested it out, and they will almost certainly replace the charger for you at no cost.
Oct 11, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
253 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
