Question about Mitsubishi XL8U Multimedia Projector
2 red lights on, no blinking. And no bulb on is the bulb burned out?
Mitsubishi xl8U, red power comes on and then red status light comes on . no blinking and the bulb dose not come on. Is it a burned out blub?
    Problem Solver:
  • 8 Answers
I think ur sytem in stand by mode / pcb complaint related to microcontroller.
Posted on May 28, 2009
How do I fix the Television that has a constantly blinking re status light and will not come on?
re-install the lamp door cover if you own a mitsubishi. they wont run without it.
Jan 28, 2015 | Televison & Video
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Why is the Status Light on my Mitsubishi XL8U flashing red? My projector is still working but the status light flashes red.
With out knowing the state of the power LED, my best guess is the Status light is solid red and telling you to purchase a replacement lamp before the current one dies. Attached is a chart that will show you the errors possible depending on the LED statuses:
Mar 11, 2011 | Mitsubishi Lamp For Mitsubishi XL8U...
Hi, My hc1500 Is having a problem. When I turn it on it makes a clicking sound. Then the Lamp fails to light. The Light is green and the status is green, but soon after the projector shuts off the power...
The clicking sound is the high voltage power supply trying to
ignite the gas in the lamp. The lamp is not firing and coming on.
Check the bulb/ lamp life. Possible the lamp has exceeded its
useful life and may need to be replaced.
Jul 16, 2010 | Mitsubishi HC1500 DLP Projector
Powers on for only a few seconds
if the power light blinks and the status light is off, check the lamp door. if the power light blinks and the status light is steady red or blinking green, you have a power supply/ballast issue. you may have to send it in for repair. try www.avsolutionsny.com.
Dec 09, 2009 | Mitsubishi XL8U Multimedia Projector
Replaced bulb in Mitsubishi WD-52525 and it still does not work
Press the input/device button and the menu button at the same time. Green LED will blink a two digit code blink 1st digit short pause blink 2nd digit longer pause and repeat. Any number of problems can cause this same symptom.
If the red LED your refering to is the Status LED and not the Lamp LED then you have big problems. A red Status LED indicates no communication from the Format board to the DMD board (light engine). 1/2 the time caps on the format board itself the other 1/2 must send entire electronics package to Mitsubishi.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Problem on Bulb Change Out
Simply hold down the left and right arrow buttons along with the power button for 3 seconds and the unit will reset itself and come on.
Dec 10, 2008 | Mitsubishi XL8U Multimedia Projector
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Oct 28, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi XL8U Multimedia Projector Logo
409 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Martin Murray
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
