Question about Coleman Cable Coleman Inflatable Boat Paddles
Canoe has damage on the front bow.
My coleman ABS plastic canoe needs the front bow repaired. It seems to be made of ABS plastic, but cannot find any repair procucts for it. Can you suggest anything? Thanks, JBY
    Problem Solver:
  • 12 Answers
Try www.bullseyetradingpost.com I know they have a repair kit for cracks and holes. I understand they are working on a skid plate for plastic canoes as well.
Posted on Dec 11, 2009
    President:
  • 1,489 Answers
Bondo would probably work.
Also, you could laminate a few pieces of something like vinyl siding/facia board over the hole. If the canoe is ABS, the vinyl siding cold be "welded" / fused to the ABS with PVC primer & solvent/cement.
Posted on May 27, 2009
  • Samuel Charles Spriggs May 27, 2009
    You tried this already and it didn't work?
Abs and brake lights coming changing front brakes on 2008 Chevy silverado
Check wheel speed sensor that it was not damaged during brake job. Once the the speed sensor is right, you may not need to rest Module, it will reset upon driving.
Mar 10, 2015 | Thule 2008 Chevy Silverado - Extended cab...
I have a really old coleman canoe & the front seat support bars are broken.Any ideas how to repair or where to find replacement parts? Coleman says its discontinued so no parts from them.
Compare with a Pelican canoe, and see if its parts will fit.
Alternatively, make something similar out of aluminum tubing or hardwood.
Do consider if the boat is actually worth fixing. A used Coleman can be found for $250-350, and if you do much canoeing a used (better canoe) can be found for $450-550 in most areas.
Jun 05, 2014 | Coleman Boating
I can't find any id on my old scanoe, how can i get an id number for it.
I have one from the 1980's and found numbers stamped on the side stern quarter, hard to see
Mar 21, 2011 | Coleman Boating
My tripper has the bow worn down by constant running on ground and hitting rocks. What materials do I need and how do I repair it?
Try bullseyetradingpost.com they were working on a skid plate for poly plastic canoes e-mail and ask for help! they were very helpful with solving a few seat problems for me.
Aug 05, 2010 | Old Town Tripper Canoe (17' Royalex(R))
How do I fix my badly faded canoe, colour is red and only faded down one side?
I would recommend painting it with a type of paint that would adhere to the material the canoe is made of whether that is aluminum, fiberglass, etc. My guess is that you have been leaving only half of the canoe in the sun, so when you store the canoe, either keep it in a shaded area or cover it with a tarp to keep the sun off.
Jun 06, 2010 | EA Sports Pelican Int'l. Colorado 15' 6"...
Colman Canoe Bracing Gone Loosing Shape
Your going to have to replace the bracing, the poly plastic your canoe is made of needs it to retain it's shape. If its an older one the bracing should be made of aluminum tubing, you can buy this then cut to size shape and fit to your canoe. If its a newer one say made by pelican {they took over for coleman} its made of plastic this will prove to be harder to do. Either way its a big job
Nov 08, 2009 | Boating
Small crack in hobie kayak
what is the canoe made of... it may not look pretty but fiberglass will work.... you can sand and paint it later as well
Mar 26, 2009 | Hobie Mirage Outfitter Kayak
Popular canoe material
ABS, or acrylonitrile butadiene styrene, has earned a reputation among canoeists for near indestructibility. It is one of the most damage-resistant canoe materials in use today. Badly dented hulls, even those that have literally been bent around a rock, have been restored to their original shape, without cracks or leaks, by the application of heat. Canoeists have dubbed ABS craft "rubber boats" and with good reason. Since the material tends to flex slightly, it is forgiving, tending to slide over rocks, or bounce off them, with little more than a surface scratch. Some of its limitations are marginal buoyancy - it will float when capsized but just barely, so don't expect to climb into a swamped ABS canoe to await rescue, or to hand-paddle it ashore. Also, when wet, the floor of an ABS canoe is slippery, which can prove troublesome in rapids. ABS canoes require little maintenance and can be left outdoors all year - although ones with wooden gunwales and peaks should be propped to avoid ground moisture. ABS canoes also require special epoxy resins for repairs.
Dec 01, 2008 | Advanced Elements Straitedge Canoe
Gear for canoes
Here's a list of some of the other gear we would suggest: - A sturdy roof rack on your car (it will greatly reduce problems and add to your enjoyment). - Bow and stern tie-down lines - these are critical to the safe transport of your canoe when you are on the road. - A set of wheels to make getting your canoe to the water easier. - A bailer and sponge. - Padded canoe seats for longer journeys. - Dry bags to keep extra clothes and snacks protected from water coming in off your paddle, as well as from bow spray or rain.
Coleman Cable Coleman Inflatable Boat Paddles Logo
1,005 people viewed this question
Top Coleman Cable Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Coleman Cable Boating Expert? Answer questions, earn points and help others
