Question about Canon PowerShot G10 Digital Camera
Error e32 on canon g10
When I try to power it appears on the screen the word "e32" and the camera automatically it powers off
Just bought a Canon SX210, I can take only a couple of shots before the Camera gives Camera error E32 and shuts down, this is a consistent. Any hints?
Posted on Jun 26, 2010
    Problem Solver:
  • 5 Answers
Since your camera is a Canon and you are experiencing an E32 error message, we'd refer you to this site: www.camerasandparts.com They just do the Canons, they aren't expensive at all and the work through them on the Powershots is superb! They'd be the place to help you on this one. Most of their service packages for the error codes are $89 with the parts / labor included , the servicing for the camera is covered, plus the shipping on the way back is covered. The best part with them is their work is excellent on the Canons. Hopefully that helps to get you going with it. Good luck
Posted on Aug 22, 2012
Hello everyone,
I'm posting this even though I have a Canon SD1400 IS because this error seems to be a pretty common error among different Canon models so...
If your camera lens is working fine (expanding and contracting unobstructed) and your camera sometimes seem to work and sometimes fail, then I'm sorry to say that your camera is about to bite the dust.
At least in my case I found that it's a bad hardware design on the SD1400 IS camera.
I have posted a lengthy post over at G+ with pictures of my findings.
I basically discovered that the E32 error can be caused by a bad design where a data cable (or otherwise known as flex cable) inside the Optics Module has or is about to permanently fail due to a fold caused by pressure and the normal lens operation (popping in and out) makes this fold to break, thus causing intermittent problems at first and permanent damage eventually.
If you want to see some pictures check this link: https://plus.google.com/u/0/?tab=XX#102193860939068988436/posts/U74ahn9hgLs
Posted on Dec 28, 2011
Question about Canon PowerShot SD1300 IS Digital ELPH Camera
common problem ask the photo shop.
1- the powershot is set on when the battery is to low
then the lens will be blocked due to less current.
2-the lens is blocked bij a little tiny sandpiece.
Jan 24, 2018 | Canon Cameras
How to fix E32 error on canon powershotSD1300IS
This error normally comes when your Canon camera lens gets stuck in the barrel itself. There are some steps which can be followed to resolve this problem which as follows,
STEP 1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
STEP 2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
STEP 3: Just push and pull the lens slightly as it extends automatically.
STEP 4: Now when the lens is in the hard surface power on your camera.
STEP 5: Try to hit the camera softly beside the lens which might solve the issue.
You can try to format the memory card completely and then reinsert to your camera which might be the issue at times.
Sep 14, 2014 | Canon PowerShot Cameras
Canon power shot A3100IS showing E32 erra, what can I do?
One of the most common causes of the E32 is that there is an issue with the lens alignment. It make be stuck in place. Does your lens work in and out when you power up and down your camera? If so, there may be a hardware error causing the issue. If you are fortunate enough to have an authorized Canon dealer/shop in our area, you could take it to them and let them look at it.
Otherwise, if there is a local camera shop or a camera club nearby, you could seek additional help there as well. As a last case scenario, you could take it to a Wolf Camera or Ritz Camera which is a big-box camera store if there is one nearby.
Nov 19, 2013 | Canon PowerShot A300 Digital Camera
Error e32 sx210
Getting Canon error codes usually means a trip to the Canon service center for a fix. There's a discussion in the DPreview forum regarding the same problem.
Apparently an E32 error code results in the camera powering off in exactly 60 seconds in the playback mode. It not necessarily affects just the G11 but other PowerShot models too.
Generally E-series error codes mean either a hardware or firmware issue that cannot be rectified by the end user.
Hope this helps
Positive feedback ALWAYS welcome :)
Mar 03, 2011 | Canon Cameras
E32
Since your camera is a Canon and you are experiencing an error code, we'd refer you to this site: www.camerasandparts.com They just do the Canons, they aren't expensive at all and the work through them on the Powershots is superb! They'd be the place to help you on this one. Most of their service packages for the error codes are $89 with the parts / labor included , the servicing for the camera is covered, plus the shipping on the way back is covered. The best part with them is their work is excellent on the Canons. Hopefully that helps to get you going with it.
Jan 07, 2011 | Canon PowerShot G10 Digital Camera
Error msg E32
Its showing an error message. As its new take it back to the vendor and get them to sort it out, replace it or give you a refund. Its still under warranty, you don't want to void the warranty by messing about with it.
May 02, 2010 | Canon IXUS 970 IS Digital Camera
Lens error in a Canon G10
Try restarting it a couple of times. If that doesn't make the error go away, the camera needs to be serviced. There is a really good site and all they service are Powershots. They are wonderful if you need to get service for one of these Canon Powershot cameras and they are really reasonable for the cost. Your problem is on their site. Try going to: www.camerasandparts.com Look at their service and repair and you should see it there. They are amazing for service on these models. I wish you a lot of luck with it, that's a really great camera.
May 09, 2009 | Canon PowerShot G10 Digital Camera
Canon PowerShot G10 Digital Camera Logo
6,762 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
