Question about Samsung CLX 3160fn All-In-One Printer
Printer not printing dark enough
Printer will not print dark enough - have replaced ink and toner still too light to read model clx3160fn
    Genius:
  • 1,550 Answers
Go to the print settings select the dark scale
u can get print darker than the previous
Posted on May 27, 2009
My Samsung ML2855ND laser is not printing dual page after ink cartridge has been changed
Dear
The toner cart. replaced has to be checked. If its alright, try to adujust darkness and resolution of the print on printer setting. This may helpful.
Thanks.
Aug 02, 2014 | Samsung ML-2851ND Laser Printer
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Mar 18, 2014 | Sharp AR-M455N Copier
Ink is not printing dark enough
Make sure there is toner.
Replace the transfer roller
Replace the toner
Replace the fuser.
The holy trinity of laser printing problems.
Dec 18, 2012 | Dell 1110 Laser Printer
How to reset toner on hl-2280dw
Read the manual.
Get onlineand got to www.google.com In the google search box type: "Brother Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals.
May 24, 2012 | Brother HL-2280DW Laser Printer -...
Epson sx400 has just stopped printing, it only produces a plain sheet of paper. I have checked the printer queue, switched on and off but am a loss
Ensure that the printer has enough ink/toner if you haven't replaced this in a while this could be the cause (if it's ink and you haven't used it for ages the ink may have dried up) (if it's toner, take out the toner cart gentally and lightly sway it from side to side and re-insert the cart, this can let you get some more printing out of an "empty" cart)
if you have replaced the ink/toner recently try printing off a test page from the printers software or alternativly the windows printing device menu
Mar 29, 2011 | Computers & Internet
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
Hi
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Regards
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
My printing colour is not dark enough to be readable. I changed another new toner cartridge but the prints were still the same
Hi..
Not just the print cartridge but make sure that the "Print Head" is also working fine. ink clogging has not taken place on print head.... Print head is a hardware, on which cartridge is attached.
Hope this has helped you.. Thanks..
Sep 29, 2010 | Samsung ML 1610 Laser Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
How can I make my laserjet prints look as dark as my designjet pr
It si not possible because the %darkness of the black ink and the black toner. The first is near 93% black and the toner even at ***** eye looks dark gray less than 90% black.
Jan 12, 2009 | HP DesignJet 4000 InkJet Printer
HP Laserjet 1022
Have you refilled the toner cartridge or is it refill as when these toner cartridges are refilled they have a tendency to leak. I suggest to remove toner cartridge turn the machine off vacuum out the inside and replace the toner cartridge with a new original. Run 20-30 prints through to get rid of any other loose toner and then should be fine.
If printing doesn't improve then repeat process if still same problem suggest transfer roller to be changed.
Hope this helps
Thanks J
Nov 15, 2007 | HP LaserJet 1022n Printer
Samsung CLX 3160fn All-In-One Printer Logo
806 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
