Question about Belkin (F5D7231-4) Wireless Router
Can't access Belkin setup page 192.168.2.1 anymore.
Tried to secure my wireless connection, but all I did was stop my Belkin adapter from getting internet access. I now can't log onto my Belkin router setup page anymore. Can't I just reset this? I can get online fine, but I want to undo the WAN username and password, but I can't access 192.168.2.1 anymore. I keep getting a search page.
  • bgamble19 May 27, 2009
    I pressed and held the reset button, but it keeps taking me to a search page. I tried to put the numbers in manually myself, but then I stop getting internet access. I want to change the username and password on my router setup page, but I keep getting a search page instead. Know any other ways?
  • 916 Answers
There should be a small reset pin hole in the back of the device. Hold down the reset button for 15 seconds and it should reset the router to factory defaults
Posted on May 27, 2009
  • machadojr_fe May 27, 2009
    Once reset it should be the default passwords. Type in the address bar at the top where it normally says www.google.com type in 192.168.2.1 and press enter.
Do I have to use Belkin router to be able To use the adapter?
No. It will work with any router. You will just not be able use the auto security setup feature. But doing it manually is a piece of cake.
Nov 18, 2010 | Belkin Play Wireless USB Adapter (F7D4101)
HOw can I find out my WPA Key?
try to access the setup page of the belkin router.
type 192.168.2.1 or 192.168.1.1 or 192.168.0.1 on the address bar of your internet browser. type in the password for your router. Then you'll be able to see the setup page of your router. Just go to the wireless settings page of the setup page and checkout what the wireless security key is. Tell me if you have anymore problems.
Sep 18, 2010 | Belkin Computers & Internet
We have a belkin.49ed router and hooked it up. It
The wireless security of the Belkin must have been enabled. Use a computer wired to the router to access the setup page and get the network key.
In the address bar of your browser, type 192.168.2.1.
By default, leave the password blank.
Once on the setup page of the router, go to Wireless -> Security. You will see the network key here.
On your laptop, view the available wireless networks and you should see your wireless network name or SSID, then when you click connect you have to enter the network key.
I hope this helps!
Jul 18, 2010 | Belkin Wireless Share Router (F7D3302)
The belkin rounter of my dad's laptop was installed without password setting. i tried to set it up on 192.168.2.1 configuration page. i was notified that the rounter will restart again itself...thereafter...
If you can still remember the password that you entered on the configuration page, follow the steps below:
1. In the lower right corner of your screen (near the time and date), right click on the wireless network connection icon, then select view available wireless networks. Or, if your wireless adapter has its own wireless utility, you should see that in the lower right corner of your screen.
2. You should see the router's wireless network name (SSID). By default, the SSID is "belkin54g". Select the SSID and it will prompt you for the network key.
3. The network key is the password that you entered on the router configuration page.
If you cannot remember the password that you entered, follow the steps below.
a. Connect your computer to the router using an ethernet cable.
b. Access the setup page by typing 192.168.2.1 in the address bar.
c. Go to Wireless -> Security. Copy the network key.
d. Then follow steps 1-4 above.
For the MAC computer:
1. From the Airport menu, select the SSID.
4. When asked for a password, enter the network key that you entered on the router.
I hope this helps!
Jun 13, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
SECURITY
To enable the wireless connection, you need to access the setup page of the router.
In your browser's address bar, type 192.168.2.1.
On the Belkin setup page, go to Wireless.
You may change the SSID (wireless network name), so that you can easily identify which is your network.
Then go to Security under Wireless. You can use either WEP or WPA, depending on the capabilities of your wireless adapter. If you are not sure, you may use the standard wireless security which is WEP. Just enter a passphrase and it will generate a network key.
Take note of the network key, you will use this to all your wireless computers.
I hope this helps!
May 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I get my other computer connected with a Belkin N router(F5D8236-4)?
try to know the w/l setting of the belkin router and using the wireless utility u can connect the second computer
Feb 25, 2010 | Computers & Internet
The light stays red, won't connect.
If the light on adapter is red it means that it cannot establish a wireless connection.
We need to get the wireless settings on the Belkin router and match those settings to your xbox adapter.
Use a computer to access the setup page of the belkin router. In a web browser's address bar type: 192.168.2.1.
It will prompt you to enter your router password. By default, just leave the password blank.
Once you are on the setup page, go to the wireless tab. Take note of the SSID, Broadcast SSID should be enabled.
Then Under Wireless go to Security. Take note of the Security Mode (WPA or WEP), Passphrase or WEP key.
Now, on your XBOX, go to System -> Network Settings -> Edit Settings."
Select the SSID. Select Infrastructure for the Network mode. Select the security type if WPA or WEP and enter the Passphrase or WEP key.
Save the settings then select Test Xbox Live Connection.
I hope this works! Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated. Good luck!
Feb 10, 2010 | Microsoft Wireless Network Adapter Xbox...
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Tried to secure my wireless connection, but all I did was stop my UTStarcom adapter from getting internet access. I now can't log onto my UTStarcom router setup page anymore. Can't I just reset this? I can...
Symptom You are trying to access the Belkin router’s Web based Configuration page and you are not able to do so. You can access the Configuration page from any computer behind the router.
Resolution To address this issue, follow the instructions below:
  1. First check for the physical connections between the computer and the router. There should be a cable (cat5 or above) running from one of the LAN port of the router to the Ethernet card in the computer.
  2. If the computer is wireless, it should be associated to the Router/AP.
  3. Check for any firewalls (Mcafee, Norton Internet Security) on the computer, which should be disabled.
  4. Check for an IP Address on the computer in the range of the router i.e. 192.168.2.x (x can range from 2 to 254). The router also assigns an automatic IP address to the computers in the range 192.168.2.x (x can range from 2 to 100). For instructions on how to check the IP address on the computer, Refer to Article 13.
  5. If you are not getting an IP Address on the computer from the router you will need to manually assign an IP Address to the computer.
  6. You also need to restore the Internet Explorer browser to its default settings.
  7. Go to Control Panel and click Internet options. Select the Program Tab and click on Reset Web Settings.
You should be able to get the router's configuration page if the above instructions are followed in order.
Cause You not being able to logon to the router's configuration page could be due to the following reasons:
  1. The computer is not able to establish connectivity with the router (wired or wireless). This can happen due to physical reasons E.g.: Improper cabling, bad cable, and no wireless signals.
  2. The computer not getting an automatic IP address from the router (DHCP ** assigned).
  3. Firewalls (Mcafee, Norton Internet Security) on the computer blocking the communication between the computer and the router.
  4. Improper browser settings (Internet Explorer)
** Dynamic Host Configuration Protocol
Summary The Router is a configurable device and you can manually log into the router’s configuration page to set its various operating parameters like connection type, security features and options to update the router’s firmware.
Jun 22, 2009 | Belkin (F5D7231-4) Wireless Router
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Belkin (F5D7231-4) Wireless Router Logo
2,588 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
