Question about General Electric WBVH6240HWW Front Load Washer
NOT DRAINING, STAYS SOAPY
NOT DRAINING STAYS SOAPY
I had the same problem once, there is a trap in the bottom, if you take the bottom panel off there is what looks like a turn dial if you pull that out and clean it out it should drain better it catches everything lint, change you name it. but you will want something to put underneath it there will be water in it. hope this helps
Posted on May 28, 2009
Washer is filled with soapy water and will not drain to finish rest of cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 27, 2011 | Washing Machines
Dishwasher will not drain
Most of these will either be draining all the time or not draining because of the open or close position of the plunger that controls the draining,When timer go,s bad it still times and turns but not on time,when it stays draining for 90 seconds and and stays draining after it should have shut off ,,well it burns out and freezes that plunger that operates the draining of the dishwasher.Thus both timer and control plunger need replaced,,over a 100 dollars in parts,GET A NEW DISHWASHER
May 12, 2010 | GE Nautilus 24" Built-in Dishwasher
Soapy water standing in bottom not rinsing soap off dishes
It sounds as if it is not draining. Try to trace the drain line under the sink. Usually it goes into a disposall. The port where it connects to the disposall may be clogged. Another thought. If you had the disposall replaced recently they may not have taken the knock out plug out which would give the drain water no where to go.
Apr 09, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washing machine not draining.
Hi thanks for te question. the lid switch is more likely to have failed ,because no drain or spin. check that.
Oct 07, 2008 | Washing Machines
My whirlpool washer (calypso) will not drain... It is flashing a code "LD" and soapy water is still in the bucket.
The drain pump has either failed or is blocked. If you can hear a humming noise while draining, the pump contains a blockage.
Jun 04, 2008 | Whirlpool Washing Machines
General Electric WBVH6240HWW Front Load Washer Logo
282 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a General Washing Machine Expert? Answer questions, earn points and help others
