Question about Crosley CDE6000 Electric Dryer
Crosley CDE/CDG22b7 The dryer makes a loud rolling noise when operating. I cannot figure out how to disassemble the unit to look under the drum - it looks like I have to take the unit entirely apart to trouble shoot the where the noise seems to be coming from. I also cannot find a repair manual online. I would like an idea of where this noise might be coming from or a way to easily disassemble the unit without having to take the entire dryer apart.
  • 1 more comment
  • dryerWoes Oct 22, 2007
    It sounds like the drum is either out of round, or it's hitting the sides of the unit (it's not, I ran the unit with the top pulled open) and it's quite loud. Almost as if there's something hitting the drum.
  • Qdanj Nov 24, 2007
    I have a similar problem. It sounds like a worn bushing on an idler/tensioner pully. The noise is irregular in rythm but constant. It appears that there are screws along the bottom of the sides that hold the undercarridge on. They are torx 20 x 50 (which in itself is fairly annoying).
    I was hoping to have a quick look and order whatever parts appear to be at fault but this dryer looks like it needs a little work to get inside. Anyone know of an easier way to diagnose this issue?
    Dan
  • Dryerfix Dec 29, 2007
    How do you take it apart to get access to the drum?
  • 94 Answers
Please describe "rolling noise".
Posted on Oct 21, 2007
Dryer making loud noise
Could be a few causes, but the most common is the drum roller wheel or wheels may have a bad bearing.
Oct 21, 2015 | Asko T761 Electric Dryer
Crosley CDe 8000 dryer. Dryer won't turn drum
If the motor runs but the drum does not turn it sounds like you have a broken belt
Aug 06, 2014 | Dryers
How to disassemble drum from shaft of cw6000w model
my washer agitator will not move or make its usual half turns it makes loud noise i went out and bought a new bas for it tryed it no luck went to take spline off offdrum to fix gaskets or whatever just to check wont come off
Dec 09, 2012 | Crosley CW6000 Front Load Washer
I have a loud noise coming from the bottom right side of my dryer. I am trying to figure out how to open the cabinet up to see what the actual problem is but I can not tell how to open it. There seems to...
maybe the drum rollers,Tim:
http://www.partselect.com/dryer+maytag-atlantis-drum-removal+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
May 29, 2011 | Maytag PYE2300AY Electric Dryer
It makes a very loud squeak while the dryer is going. but it is not a constant noise. what could be causing this
drum roller/glides:
Feb 16, 2011 | Crosley Dryers
I cleaned out my lint tray and after I put it back in, the dryer started making a grinding noise?
Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a squeak.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
May be loose drum slides can cause a metal scraping noise as the drum rotates. For that you'll need to contact Crosley Service Center.
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 02, 2010 | Crosley CDE6000 Electric Dryer
The dryer is making a loud noise when running. the drum is turning. almost sounds like something is rolling around under the drum.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
6565ggf
Feb 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
My CDE6500 is making a loud tumbling noise while in cycle. It drys fine, but as loud as can be. Can anyone help me ?
There are a couple rollers that the drum turns on that have probably got bad bearings and need to be replaced.
Jul 08, 2009 | Crosley CDE6000 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
266 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
