Question about Kenmore Elite Oasis 27052 Top Load Washer
Stripped gears The gearing in my kenmore elite are stripped. It's not the acutal gears, but the engaging 3 prong gear(referred to as a dog by a buddy) that is worn. I have removed the top cap of the inside pillar and i can see the gears,and "pronged gear", but i can't figure out where to go from here. I have completly removed the washer housing and the drum is no exposed, sitting on the frame with the motor and transmission. Thanks for the help.
  • 15,935 Answers
It wasnt necessary to remove the shell. The agitator dogs can be replaced from the top through the lid.
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • pathall Feb 04, 2011
    Just wanted to say THANKS for the write-up! I have this exact issue and appreciate your time responding.
Noise when shifting gears
transmission synchronizers most common cause of transmisson noise in certain gears, and not others, might want to check the gear oil level. Transmission rebuild required. To read about them and what they actually do, then here is a good read:
When you shift gears in your standard shift car, you move a rod that moves a fork that engages the gear. Depending which gear you're shifting to, a different fork does the job. The fork moves the collar to the desired gear, and dog teeth on the collar mesh up with holes on the gear in order to engage it. You engage reverse gear through a separate, small idler gear. The reverse gear always turns in the opposite direction of the other (forward) gears.
In years past, double-clutching was common in order to disengage a gear, allow the collar and next gear to reach the same speed, and then to engage the new gear. To double-clutch shift, you pushed the clutch pedal to free the engine from the transmission. Then the collar moved into neutral. You released the clutch and revved the engine to get it to the right rpm value for the next gear so the collar and the next gear spun at the same rate to allow the dog teeth to engage the gear. When the engine hit the right speed, you depressed the clutch again in order to lock the collar into place on the next gear.
Modern cars use synchronizers in order to avoid the need for double-clutching. A synchronizer, or "synchro," lets the collar and gear synchronize their speeds while they're already in contact but before the dog teeth engage. Each manufacturer's synchro is slightly different than the others, but the basic idea is the same. For instance, a cone on one gear will fit into a cone-shaped depression on the collar. The gear and collar synchronize their speeds thanks to the friction between the cone and collar. Then the outer part of the collar moves out of the way so that the gear can be engaged by the dog teeth.
Dec 16, 2013 | Chevrolet Silverado 2500HD Cars & Trucks
Kenmore elite washer model 24952300 not agitating
Possible that the belt or the agitator has come off from the base and so does not connect. Please check this link: Washing machine
Jul 04, 2012 | Kenmore 24032\24036 Top Load Washer
I have a 2009 yz250 with a good amount of time on it and i believe 2nd gear is out of it. it grinds n almost sounds like a chain slipping when i get on the gas and is like its in neutrel. what does it take...
Yes, the case will need to be split. The problem is likely to be a bent shift fork. A bent fork can stop the dogs on the slider gear from fully engaging in a gear. If the problem turns out to be a stripped gear, you need to replace BOTH the stripped gear AND the gear the bad gear meshes with. tombones49_273.gif
Sep 02, 2011 | 2003 Yamaha YZ 250
Have a yamaha 660 raptor and when I shift into second gear it's like it's not engaging in. I pulled the motor apart and can't see any stripped gears at all.
The bike has a bent shift fork. Identify the fork that is supposed to move the slider gear to engage second gear then replace the fork. Note; the fork will look okay to the eye. You can't see the bend even when comparing the old fork to a new one. Check the gear dogs on the slider gear. Are any dogs broken? tombones49_258.gif
Aug 20, 2011 | Yamaha XT 660R Motorcycles
When i spin the wheel on my scooter back or fowards there is a sound of knocking but only when changing diections it only clanks wen it engages the hub if you know wat i mean thanks paris it is a...
This is normal. A slider gear engages into rectangular slots in a drive gear. The slots allow the dogs easy engagement into gear. The knock you are hearing is the engaging dogs striking each end of the driven gear. Please rate my answer, thanks.
Aug 25, 2010 | Yamaha YZF-R125 Motorcycles
Second gear feels to be dropping out/or skipping on my gsxr750 when under load(hard throttle or with a passenger). what is the most likely cause
Hi
I'm sorry to say that it's the dogs on the gears (the bits which engage into slots on idle gears)
After a while the edges of the dogs & slots get worn & the engine will jump out of gear especially under hard load
It's a gearbox strip & UK£80+ per gear, off which you will probably need 4 or more
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!) - it helps my ratings
May 10, 2010 | 2000 Suzuki GSX-R 750
My sons klx 110 grinds when downshifting
While sitting still the gears are not moving. This sounds like a slightly bent shift fork. In the diagram below the slider gear moves left and right to engage the gears. The gear "dogs" fit into holes cast into the stationary gears. The grinding takes place as the fork moves the slider into first gear but the dogs are not getting moved the full distance needed to fully engage the gear because of the bent fork. The center case must be split to gain access to the gears and shift forks.
A “very helpful” rating for this answer? Thanks!
Jun 30, 2009 | 2006 kawasaki KLX 110
Suzuki Savage 650 LS 4 gears found not 5. I just bought a 2002 Suzuki Savage It runs great, plenty of power but I can't find 5 gears only 4. I've had it to 65 and had no over-reving. Am I missing...
Your bike has a fifth gear. The problem is probably a bent shift fork. Broken engagement dogs could be present but I have never seen that happen in anything other than 1st and second gear. This is approximately an $800 to $1000.00 repair. Personally, I really like only having to shift 4 gears. Don't you?
Below is a partial image of your trannie and also a generic image showing how a slider gear moves left and right when pushed by a shift fork. In this example the gear dogs engage into either 1st gear or 2nd gear depending on which way the fork moves the slider gear. If the fork were bent, the slider may go into second gear but not have enough movement to reach first gear. If the gear dogs were broken off then the gear has no way to engage.
I don't get paid for my answers but I do take pride in them, I just try to help where I can. So if you feel it is right, > > A “very helpful” rating for this answer? Thanks!
Jun 28, 2009 | 2002 Suzuki LS 650 Savage
Virago 535 gear change problem
The crunch is the slider gear dogs engaging into a gear. Slower revs will lessen the impact of engaging. Good clutch springs is the heavy clutch. Be glad.
Please rate this answer. Thanks valkathain!
Apr 20, 2009 | 1996 Yamaha XV 535 Virago DX
2001 Rav4 gearbox problem.
gears slipping out of mesh indicates
1 ---not properly engaged on selection
2--- failing output shaft bearings
3-- worm slip joint bush in the extension housing not maintaining alignment of the output shaft
The gear engagement is by dog teeth in the synchro ring for 5th gear and if that connection alignment is not maintained exactly by bearings and bushes the dog teeth move out of engagement at each revolution
AS reverse gear operates through a moveable spur cut gear to engage the counter shaft and the out put shaft and you are having trouble with reverse as well , indicates the out put shaft rear bearing is suspect or is moving in the box housing
Dec 07, 2017 | 1999 Toyota RAV4
Kenmore Elite Oasis 27052 Top Load Washer Logo
220 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
